Originally Posted by Alf
I replaced MAX1722 with TPS6734 and LM317A. Both ICs are cheap and easy to get. This gives us 9V from USB to power an amp. It will not be as good as TREAD but should do for portable use.
Schematic v4
When reading this post I have assumed the LM317A is similar in noise and impedance behaviour to the larger 3 pin LM317T package.
A couple of questions/suggestions and something for everyone to read on power supplies:
- Looking at the schematic for the LM317A there should be a cap over R15 (between adj and gnd) as this reduces noise.
- Should we have 2 diodes (1 across the input/output & 1 across the output/R14) for protection it the case of the output voltage exceed in input voltage on shutdown, which could cause damage (maybe)?
Have a look on the datasheet for examples of this.
We also have to pay attention to the input and output caps for this regulator (ignoring 100nF caps). There is no large input cap and a 2 output caps currently - C25 (33uF) in parallel with C3 (1000uF). Not ideal at all, see the datasheet.
[edit] Oops, I missed seeing C20 (33uF) on the input but we still need to do something here as the output capacitance is far greater than then input capacitance.[/edit]
We need something before the regulator (let say ~1000uF) and a medium sized (lets say ~220uF) cap on the output. The output cap should have a medium ESR (not low ESR). What will adding a big cap on the input do to IC1 (TPS6734)? Need to check this guy also but guess it will be okay.
Why? I can try to explan badly but the easiest way it to have a read of these articles on TNT-Audio based on testing the LM117/317. The tests are based on the 3 pin version but should be applicable to the A version (similar technology I presume).
http://www.tnt-audio.com/clinica/solidstate.html
particularly:
http://www.tnt-audio.com/clinica/reg..._noise2_e.html
From this article:
"....bypass[ing] the adjustment pin, in our case with a 22uF ZL. And what happens? Noise is reduced tenfold with about 20dB."
and:
http://www.tnt-audio.com/clinica/reg...edance1_e.html
From this article:
"The output impedance of the LM317, even at DC, depends strongly on the load current, with impedance dropping with increasing load. This is not new, and it is precisely the reason why it is always recommended to ensure that such a regulator chip sources at least 10mA, preferrably 30mA, no matter what the actual load demands. At 100mA and more the impedance goes as low as 30mOhms or so, turning inductive above a low 400Hz. This is typical for a circuit relying on loop feedback, using an error amplifier with not a lot of gain and not a lot of bandwidth."
[OK, we have a load of ~40ma for our DAC and this is could be area where the 317T & 317A could behave differently (maybe), but is still important to think about it.]
and
"Adding an output capacitor effectively bypasses the regulator at higher frequencies. As the LM317 is inductive in these regions, this makes for a resonant circuit and hence some damping in the shape of a not-too-low capacitor ESR is called for: it is good to follow LM317s with a relatively big cap, but it is bad to use a low-Z cap there!"
[Need to do something about the status of the input and output caps.]
All the TNT Audio articles are worth reading as they have interesting info on different types of regulators.
Just my afternoon post for the group, back to work now. Lets keep the evolution of this design going.
Botch...
