Alf
- Dec 28, 2004
I updated the schematic and the board. It took me quite long time to implement all suggestions Francis made in his last post (keep them coming!). I re-shuffled nearly all components on the board making the layout more efficient. I hope I got it right this time!
Schematic v2
Board v3
Changes:
* New board size 50.5mm x 54mm. Now the board is 3mm shorter.
* Added a power switch (I guess it may be useful).
* Added C19.
* Moved the bypass capacitors closer to IC pins and rotated them. It is possible to move C10, C11, C14 a bit closer the board (~ 0.6mm) but not C13 and C12. The layout looked really ugly when I moved the capacitors. So I left them lined up.
* Optimized layout around the crystal and MAX1722.
* Many other minor changes.
I have been in contact with Maxim regarding MAX1722. They can supply me with any quantities (50+) of MAX1722. The bad news is that the final price including postage, taxes, and fees will be around 3.0-3.5 USD each. I may be able to bring the price down. I will keep you posted on this.
Now I am going to investigate potential replacements for MAX1722 and what can be used if the low voltage battery option is dropped. Any tips are welcome.
Schematic v2
Board v3
Changes:
* Added C19.
