Francis_Vaughan
- Jan 30, 2005
Alf, yes, there is some good improvement in some of the caps, and indeed C18 was the one I was referring to as sub-optimal. Actually around the IC the ground plane is OK, and the bypassing in that region is OK - although tweak-able still I bet. But the damage to the ground-plane everywhere else seems just plain odd. Getting a totally continuos ground-plan under the IC would be good however.
Why stop using the other side? It just seems weird to have moved so many traces onto the top side - where they cut up the ground-plane - for no good reason.
With the cut up ground-plane you invite all sorts of cross coupling and resonances and invite much disturbance of the ground.
For instance, there is a loop that starts at the IC ground-plane, heads down, left across the bottom of the design, up under the USB socket, up, past the 12 volt pin, around C15, right, under C14, under crystal and under the IC. This will pick up RF energy, and couple it into anything nearby, including the IC and the analog power trace. There are also long spindly bits of ground-plane with bits hanging off them that look for all the world like small capacitors and inductors teamed up.
