PC Enthusiast-Fi (PC Gaming/Hardware/Software/Overclocking)
Jun 29, 2015 at 1:03 AM Post #8,221 of 9,120
@ibob4tacoz is that even a question, it's clearly well done... A proper case and a little patience does wonders...
Modular PSUs is for saving space and hassle. If you are planing on using 2 SATA power plugs, and your mobo has 6 of them on 3 different cables, would you rather have those extra 2 just sitting there? Or would you want them taken out. There is also cables that aren't used or are used in a small number of builds, like 4 fxxking PCI-E cables, for GPUs, not a lot of people have 4 GPUs, so having the ability to take them out is important. Fully modular pretty much presents the same ideas, but takes it further. Yes, there is no rig that doesn't have a 24-pin cable, but does your rig need a 2.5 foot cable? In an ATX build, hell yeah, but an m-ITX, hell no. Just more things to tweak.
It's a 24-pin for the record, or 20-pin if your mobo is ancient.
Jun 29, 2015 at 1:17 AM Post #8,222 of 9,120
I fail to see the point of 'fully modular PSU' though, it's not like anyone going to buy a PSU and not use the 12-pin motherboard cable...
Custom colored/braided cables. People like that stuff.
Jun 29, 2015 at 1:51 AM Post #8,223 of 9,120
I know the advantages of modular PSU, just wasn't so sure of the advantages of a fully-modular one...
some cases have multiple PSU spots so you can seriously have a separate PSU for GPUs or audio cards, etc...
Edit: also, some people may buy pre sleeved modular cables and then they can just get a new 12 pin one.
...and I guess now I know. I previously cannot think of a reason why would anyone need a PSU with detachable 12-pin cable.
Jun 29, 2015 at 8:49 AM Post #8,224 of 9,120
Really liking my SLI 980 TIs, almost went with the Fury X but AMD's drivers always end up disappointing me at some point.
and custom lengths, for those with huge, tiny, or irregular size cases.
Jun 29, 2015 at 9:14 AM Post #8,225 of 9,120
Or idiots like me who got a mid tower case with a micro ATX board
Jun 29, 2015 at 2:37 PM Post #8,226 of 9,120
Here's my take on cable management:
The PSU is non-modular but I used the NZXT premium cables starter pack to get all those braided extension cables. Tucked all the extra wiring between the other side of the motherboard plate and the other side panel.
Jun 29, 2015 at 3:03 PM Post #8,227 of 9,120
I do have a fully modular PSU, and don't have any custom cables. The experience has been really nice, and allows for me to reuse the thing if I wanted to in say... an m-itx build that I'm thinking about. I guess if you don't want/need it, then you don't have to buy it.
Jun 29, 2015 at 3:21 PM Post #8,229 of 9,120
I don't think I could stand SLI, how's the microstutter?
Jun 29, 2015 at 10:09 PM Post #8,230 of 9,120
Here's my rig. I could have cleaned up that CPU cable but it would require taking out the CPU cooler. I cleaned up everything else I could.
I always liked the look of Zalman coolers.
