VXAce
- Oct 1, 2013
Max settings including hairworks in Witcher 3, but I increased the GPU's temp limit before it throttles from 80c to 95c.
This makes me really covet those industrial PPC 3000rpm fans by Noctua.. But if I don't want to replace every single fan of mine with those as they are really expensive, which fans do you think I should change? 2x120mm front intake or 2x140mm top radiator exhaust?
Hmm, I'd just turn down some settings and change that limit back to stock (unless you don't mind the GPUs burning out). The limit is generally there to preserve the life of the GPUs, and I don't think anyone recommends turning it up unless you plan on OCing or doing something insane.
According to Nocuta's site, the PPC 3000 is a pressure oriented fan, so it might be better for the rad. But at the same time, they are quite loud, 44 dB, I already consider 30 dB rather loud, 44 dB is pretty high up there. Not entirely sure I can recommend them at all.
