chaZZZy007
Tubes always have at least a little bit of variance. Some are a bit more noisy and or microphonic. Its simply part of their analog nature. As always use your cleaner before you install your new tubes. Always.I upgraded my tubes to some Amperex ECC88 from Tube Depot. Nice change from the Siemens Cca tubes — warmer and easier to listen to for long stretches of time. However, after installing the tubes, I noticed some slight background noise from the InPol. I was listening to the amp with Focal Stellias, which are pretty sensitive headphones, and the intrusion of noise into the music bothered me.
So I installed Herbie’s Tube Dampers on the tubes (had to remove the InPol’s cover to put them on, due to the sharp guards around the tube sockets) and inserted an iFi noise-cancelling SupaNova power cable between the InPol and my Power Plant P5. It sounded a bit restrained and sharp that way, so I plugged the InPol directly into the wall. Presto! A more relaxed and open presentation. Plus, no background noise that I can detect anymore.
Making those two changes made the amp sound a little less warm and more precise. I’m trying to decide if I like that or not.
Personally I don't like if a power conditioner adds to the sound signature. All I want from it is a lower noise floor without hindering my gears dynamics.
I've been looking for some nice Holland tubes for my collection. I just haven't pulled the trigger yet.
Please update your experience as the tubes burn in. GLHF!
