Puck your Whammy looks great that is very creative.
PASS DIY Headphone Amp - WHAMMY
- Thread starter HiGHFLYiN9
Thanks! I don’t have vents at this point. I looked at a number of other people’s cases and it didn’t seem like many were vented so I figured I’d try it without. The bottom panel comes off with 4 screws and nothing other than the feet are mounted to it so I can vent it pretty easily later if needed.
Beautiful case work! I like that all screws holding it together are hidden. Do you have any vents on the bottom of the case?
adydula
- Dec 14, 2010
The Whammy is gorgeous Puck!!
I just popped the 883 back in from a 2134 and with the D8000 Pros its magnificent!!
I really like your walnut inset ! Its beautiful!!
Alex
Alex
adydula
- Dec 14, 2010
adydula
- Dec 14, 2010
After many, many amps of all sorts and prices this IMO is about as good as it gets for amplification.
The tube speaker amp has its left and right channels using the same ground so its an easy wiring up of adapters with step down resistors for SE and Balanced.
The pre-amp in the PassLabs HPA-1 is not an afterthought, but a world class pre-amp that I drive the speaker amp with and the sound is gorgeous with most headphones.
No worry about power etc..
I rotate thru the Whammy, HPA-1 and other amps with Y-cables from the Schiit B2 dac so I can easily have three amps on and running at the same time to quickly switch between them all very efficiently....IMO all three amps provide a great sound.
Alex
Alex
chaotic_angel
my Whammy amp with Burson amp V6 series inside.
Congratulations Whammy with the V6 is a superb way to go.
what does the knob in the middle do?my Whammy amp with Burson amp V6 series inside.
Paladin79
Previously MOT: Cables For Less
I always thought the appearance of the headphone jack on the PASS to be interesting. I built a Whammy some time ago. I prefer tube sound but if there is one solid state headphone amp I might go to it is the Whammy. Most everything I own is Class A and I have done my own designs on headphone and power amps.
In the last one I had to use some WW2 vintage pentodes as triodes in order to win a bet. Naturally I did cover the transformer in the headphone amp picture after all tests were completed. I did an all copper faraday cage in order to stay with a steampunk design.
chaotic_angel
It is a 6 steps bass switchwhat does the knob in the middle do?
adydula
- Dec 14, 2010
The jack according to the designer was picked because there were no better options out there...mechanically or electrically and they tried a bunch. They state that this xlr jack actually gets better conductivity with repeated insertions. Many hate the look...IMO its just fine...I always thought the appearance of the headphone jack on the PASS to be interesting
Paladin79
I have no issue with the connector type.The jack according to the designer was picked because there were no better options out there...mechanically or electrically and they tried a bunch. They state that this xlr jack actually gets better conductivity with repeated insertions. Many hate the look...IMO its just fine...
adydula
- Dec 14, 2010
Some folks think for $3500 retail it should be just a higher priced unit.....fyi....I have no issue with the connector type.
Paladin79
Any sentence starting with “some folks think” can be applied to most anything I do not pay for most things electronic so price is moot to me. My solid state devices tend to sit on shelves in my shop.Some folks think for $3500 retail it should be just a higher priced unit.....fyi....
HiGHFLYiN9
Member of the Trade: Zynsonix
Well... it's just a Neutrik locking connector. It probably is the most expensive 1/4" panel mount on the market. Honestly you can open up any multi-thousand dollar piece of electronics and find things that cost pennies FWIW.
