Those boards could prove handy for all sorts of projects. Keep us updatedHey all I made a few different designs based on Wayne's power supply for the whammy. The one shown is a single rail positive CRCRC filtered linear supply. This board is already in the fabrication house and I'll be fully testing when they arrive.
I have also made a board based on the pilot light schematic submitted by 6L6 which allows you to easily add a pilot or power LED to the whammy or any other amp that doesn't have the provision for a power LED. Simply tap into the transformers AC output or the power supplys DC output. I made an alteration to the original circuit by adding a variable resistor to allow you to adjust the brightness of the power LED indicator for your build. These are also in the fabrication house.
Cheers
