My WHAMMY has some extra $$ put into the components because I wanted to see how far Wayne's design could go. In particular, I found that both the shielded, medical-grade IEC inlet and the Sparkos voltage regs were worthwhile as I don't hear any noise floor, even with the pot position fully open.
I recently swapped the OPA828 for a Sparkos SS3602, and wow... I think anybody would be perfectly satisfied with the performance of this amp. I don't think it's holding back any of my TOTL cans at all.
Sure, if you're spending Susvara-levels of cash and need a ton of juice, then you're probably going to exploring other options (I'd recommend a first watt design with VFETs in those scenarios.)
I've found the WHAMMY to be quite sensitive to the subtle sonic differences of opamps. Also, be sure to check the datasheet of your opamp(s), as most call for a bypass capacitor (usually 0.1uF) across Vcc/Vee and GND.
I'm currently listening with my ZMF Atrium and it sounds so punchy, natural and "analog." My OTL may inch it out in soundstage and texture, but only just.
Highly recommended for anyone who wants a SS amp and doesn't want to surpass the $3k+ mark for marginal gains.
