yearsofwisdom
- Apr 19, 2010
arn't the klipsch custom 3s the ones with the dreadful cables? not worth it if you can't recable and you just buy another piece of crap.
Are there any cables that work with this other than the Sleek Audio cable? I don't mind paying within reason for a good quality cable that doesn't have the memory issues like the stock and if over the ear is easier instead of the long connector to the housing like the stock cable does. A normal cable length like the 1.2m most earphones have would be good as well.
Anyone know how these compare to the RE-ZEROs and the Klipsh Custom-3s?
I don't know any other headphones that use these connectors. Seems a bit odd that only panasonic and Sleek Audio would use them though. Actually, when googling around I found a mention on another forum that the cables appear to be terminated in a standard small DC jack, or something of the sort. The poster said you would probably be able to make your own cables easily by buying the necessary parts. I've been curious to try it myself =P But no, as far as I know there's only the SA cables. I really don't have any issues wearing those over the ear though.
Anyone found this IEMS in a good price (similar to J&R for 90$), from international seller? You can only find them for like 150$ included shipping
Well it definitely won't be $79 if they ship outside of the USA which may or may not be an option. I'd look into getting a mail forwarding service in the US. I don't know any as I live there but you can search for one.
Just thought should update about how unsatisfied i am with hje900.
I have returned hje900 and would be seeking a refund.
This earphone is just not my cup of tea. There is too much shrillness in voice and bass is relegated to backseat. There have been times/songs when i literally have to lower the volume since the voice of singer is too loud, sharp to my ears. Also i had to up the volume by approx 5-6 bars to get a good hearing. Not worth the effort my ears take beating for. Initially i was thinking it was fit issues, but even after getting good seal with Sony Hybrid tips, i still didn't like these. So they gotta go. It is possible that i have been given a bad piece of iem, but i won't be able to tell that since i can't differentiate between fake and real if there is any or if it was a manufacturing defect.
I don't mean to offend any hje900 users, but this is entirely my opinion. YMMV.
I guess i will have to hunt for some other iem's that possibly do some justice to my bass-head.
