edwardsean
- Jul 7, 2006
Yup! Works like a dream.
MKV blue ray and DVD rips.
The popping is probably digital clipping. Lower the gain on whatever is feeding OOYH to fix it.
I had that issue before, needed to lower my source to it to fix it originally, and those pops were originally much louder than the sound and these are not. These pops persisted and had loudness which correlated with the volume no matter which part of the audio chain I lowered the volume of. The "poping" might just be a really short duration skip/audio artifact too, maybe having to do with the fact that two programs are processing audio at the same time, making lag in the system slow both down for a blip and possibly not giving both programs enough buffer time to fix the now compounded error. I don't know much about this though, taking a shot in the dark.
Hi @thekorsen ,
Thanks for the tip about Equalizer APO. I remember trying it at some point, but I can't remember if I had any problems getting it to work with Out Of Your Head. But I am glad you have it working.
Your suspicion about why you are getting some audio artifacts may be due to both processes processing the audio signal. Plus the fact that the processes are running in real-time with fairly low latency may have some problems even on a fast computer. With the current low latency engine, even fast CPU's can sometimes have audio glitches when other processes are running at the same time. Sometimes even web browsing or any mildly CPU intensive process can affect the audio processing in Out Of Your Head. So I would not be surprised if Equalizer APO can cause audio glitches with Out Of Your Head. We are doing a fairly significant amount of DSP very quickly and I assume so is Equalizer APO.
I will give it a try on my test systems and see if I can get it working smoothly.
One thing to check in general for anyone running Out Of Your Head on Windows is to change your Power Options to the "High Performance" setting, or in the advanced settings, make sure your Minimum CPU State is set to 100%. For some reason, sometimes Windows will not "see" that Out Of Your Head needs a lot of CPU and will leave the CPU in a low power state. That can cause all kinds of glitches and distorted sound especially on laptops.
Anyway, I'll let you know if I have any luck with Equalizer APO.
Thanks,
-Darin
OK, I was able to get Equalizer APO working on my Windows 10, desktop system: i7-6700 3.4GHz and 32GB RAM.
This computer is pretty fast and it's a desktop, so it seems to have plenty of CPU power to playback 2 channel audio with both Equalizer APO and Out Of Your Head active. I didn't hear any problems with the audio even when up-converting two channels to 7.1 channels.
However, for whatever reason, I noticed that in "Effect", once I set "Spatial Setup" to 7.1 and then "Upmix" to ON, the output level from Equalizer APO jumped way up and caused some seriously loud clipping/digital distortion. So be careful!
To fix the distortion, I adjusted the "Pre-amplifying" slider on the top of the main Peace GUI down to -14 or lower. You have to play with that until you stop hearing any distortion especially on loud passages.
The clipping/distortion does not sound like the clipping I get when the output from my media player is set too high. The distortion from Equalizer APO is more like a buzzing sound.
I am not sure if that's the same problem that @thekorsen was getting, but just making sure people are aware of this.
However once I adjusted the "Pre Amplifying" volume down, Equalizer APO worked really well with Out Of Your Head. If it works on your computer without problems, I think it's a great solution for EQ-ing your audio when using Out Of Your Head.
I will try the same thing on a laptop and a slow laptop to see if I have any issues.
-Darin
darinf said:-Lots of good stuff-
Hi, just wanted to report a bug. After switching effects via pressing the up and down arrow keys every minute or so for a prolonged duration during a listening session, occasionally a popup would come up similar to what pops up after the 2 minute limit on an effect. After I X-ed out of it the audio is paused for a few seconds, then comes back on but is often distorted. This distortion can sometimes be very noticeably (buzzing and loud clipping) or marginal. Restarting will get rid of the noticeable effects, but the clipping issue seems to get additively worse as this pops up more and more and doesn't dissipate until the computer is restarted. For me, this increasing tendency to clip was experienced in lower frequencies even through the volume was not changed from the source or in OOYH. I tested this by setting it just above the point of clipping on a certain song, inducing the error by repeatedly pressing the up and down arrows to switch between effects, then exiting and reloading the program. The volume sliders were the same in OOYH and Peace, but I now had to lower the preamp in Peace another -1db to stop it from cliping.
Another bug from switching effects consistently over time seems to be a slowed time to switch effects. After a while, when a different effect is selected it will stay at bypass mode for a few seconds then switch to it.
I realize switching effects constantly isn't the desired way to use the program, and the bugs it compounds over time may well serve as a way to encourage buying the full program, but I just thought they should be mentioned.
Also, a review of the program on my different headphones is in progress. It will be my first review on headfi so it might take a while, but stay tuned.
I found a great gem for messing with stereo to 7.1 that'll always run in the background for windows! Get equalizer APO installed with the peace extension. Open it with the full interface when given the option, and select the desired configuration (7.1 setup recommended for convenience.) Next click the *Commands button and click the "upmixing 2 channels to 8" option in the menu on the upper right, then click save. Now click the *Effects button and turn on upmix with 7.1 switched as the spacial setup. I'd also recommend turning the spatial balance feature on, try setting it at somewhere between 0.6-1 for the front setting and it should help give a better front image and reduce the image confusion this configuration tends to induce. This also gives the freedom to individually EQ each channel (or channel pairs in the convenient 7.1 setup option), which might allow one to play with EQ to make certain instruments more or less present in different areas to force image separation into the mix.
One bug I'm getting with this setup however is a buzzing that goes in and out at varying volumes. It tends to get more loud and last longer over time, but closing and re-opening OOYH seems to remedy this. There are also some occasional audio artifacts (poping, skiping) and they are usually just milliseconds in duration but still distracting. Not sure what's causing these issues and they can be very annoying, detracting from an otherwise convenient solution to this.
Wow, that's a good find.
I followed the config steps, just to confirm, all this while the my EQs in the Peace GUI are flat, will adjusting those make a difference, because right now they seem to be inactive.
