PhenixS1970
Spiral Dots ++ work best for me and are very comfy (better than Azla short I have too).
I recently lost one of the tips that was my main Traillii, so I'll have to pick something up for them again when I have time. Fortunately, this is not a stock tips. After all, it would be very difficult to find them again.Listening to Traillii this morning via P6K and a recent change of tips to Spiral Dot++ which I'm now loving with the bird... Great comfort, no pressure build, and sounds fantastic. The P6K really does have excellent synergy with Traillii too.
You should delve into the topic for several tens of pages. We discussed it earlier and provided a photo. Maybe you'll find something there that you like.does anyone of you know if there is a silicone cover that covers the pavilions of the traillii?
plus a transportable case for the in ear?
That's right, this is one of the covers I had in mind)Have you tried a Dignis Arca case? It protects each IEM individually and I can even fit the Orpheus cable as it gets rolled up and placed above the IEM.
A long time ago I wrote an extensive post about tips for Traillii, but I can't remember where it was.In your hopinions which are the best tips for traillii?
I appreciate the stock tips for the best mids and voices traillii can give,but against other tips the soundstage is less expansive.
Xelastec very good but voice are recessed and on high volume can be a bit stressful.
Just bought azla sedna earfit.
Any suggestion for the best balance sound for the bird?
I use Sedna earfit light with mine and I find that they work really well.In your hopinions which are the best tips for traillii?
"3rd party" tips I source from:I recently lost one of the tips that was my main Traillii, so I'll have to pick something up for them again when I have time. Fortunately, this is not a stock tips. After all, it would be very difficult to find them again.
Thanks, mate!"3rd party" tips I source from:
https://www.mtmtaudio.com/
They do take a while to arrive (and you can ask them to reduce the value of your order for customs).
I liked the Sedna Earfit lights. Good, balanced sound, but not quite large enough for my wide ear canals. Ultimately, it's come down to finding large enough tips that give me a good seal, and the stocks are the best for that. I'd give anything for a company to make 15mm wide tips!In your hopinions which are the best tips for traillii?
You are missing Azla SednaEarfit MAX Just got those in, gotta test it, though I think their built-in flexible waxguard might be more beneficial as a "filter" for Jewel, rather than the Bird. Will check it out and let everybody know soon.I liked the Sedna Earfit lights. Good, balanced sound, but not quite large enough for my wide ear canals. Ultimately, it's come down to finding large enough tips that give me a good seal, and the stocks are the best for that. I'd give anything for a company to make 15mm wide tips!
Here's a few that I've tried. Lights, Acoustones, and Crystals worked best for me other than stock. IMO
