So thanks to all the forumer and their trial,i bouhgt Traillii,Jewel and Red Halo Fe,so i finish my small collection,included also Empire Wraith,and after reading hundreds of pages,for now seems these 3 are the best,even if many others are fantastic like Ace,XE6,Phoenix,ecc,ecc
Oriolus Traillii Electrostatic Hybrid IEM discussion thread
- Thread starter tgx78
Xinlisupreme
@gianni60 you don’t need Phönix, believe me, Ace is another beast but having Trailli and RH….
Jewel is different again and is complementary to RH/Trailli
Can anyone recommend me some god cables that can pair with Traillii, just got my Traillii recently, and I do like the original cable on it but I am wondering if there is anything great as well that makes a good combo ( i know Orpheyrus is good but I want to know if there are other options) and also First time Shielding sounds like a good option as well, really wondering there is anything else.
The original and the Orpheus are my favorites. Others have also mentioned First Times ( I personally do not feel it is worth it over the original), and the Effect Audio Centurian. None are necessary over the original unless you are looking for the last few percent.
I had the Phonix on tour and enjoyed it so much that I bought it. It sits along side my Traillii quite nicely.@gianni60 you don’t need Phönix, believe me, Ace is another beast but having Trailli and RH….
Dynamo5561
I keep both as well. Traillii and Phönix are similar to a certain degree, that's right. But Phönix has its own qualities that makes it addictive for me.I had the Phonix on tour and enjoyed it so much that I bought it. It sits along side my Traillii quite nicely.
Agreed there is a certain similarity between the two albeit Phonix has thicker mids and a bit more emphasis on bass. I feel that gives a nice contrast between the two. They are both an easy listen though and I can leave them in my ears for hours. One thing I found was that the Phonix has a more intimate sound stage compared to that of Traillii, but this works really well for some genres, such as jazz and live music. But irrespective of that, both IEMs are great all rounders.I keep both as well. Traillii and Phönix are similar to a certain degree, that's right. But Phönix has its own qualities that makes it addictive for me.
Dynamo5561
Yes! Thicker, little more bass, smaller soundstage and I'd say better treble extension. I love the treble on the Phönix. Both are very easy to listen as you say, but still exciting and addictive. And the overall package and built quality of the Phönix is unbeaten. I wish alle TOTL IEMs came with such a premium package.Agreed there is a certain similarity between the two albeit Phonix has thicker mids and a bit more emphasis on bass. I feel that gives a nice contrast between the two. They are both an easy listen though and I can leave them in my ears for hours. One thing I found was that the Phonix has a more intimate sound stage compared to that of Traillii, but this works really well for some genres, such as jazz and live music. But irrespective of that, both IEMs are great all rounders.
![Screenshot_20220719-104914_Gallery.jpg Screenshot_20220719-104914_Gallery.jpg](https://cdn.head-fi.org/a/11819004.jpg)
+1 Phonix had a little more low end. I was surprised when A/Bing because I didn't feel like I lost information.
- Both resolved at a summit Fi level and have tasteful amounts of colouring.
- Phonix had one of the largest shells that I have come across where the Traillii was on the smaller end.
-The Traillii had better instrument seperation making it my choice for ensemble music. Because Phonix had meatier mids and a more intimate soundstage, it did better for solo vocal or instrument performances. We're talking about a 10-15% difference though.
One thing I did find when using Traillii and Phonix was to give a bit of a gap between moving from one to the other. When listening to Traillii a quick swap makes Phonix sound thicker than soup, while going the other way makes Traillii seem very thin. That’s to my ears of course and it may be a non issue for others. What I tend to do is have a palate cleanser between the two. I normally reach for the Trio, or believe it or not the Blon bl03. About an hour of that allows me to swap one bird for the other.
Nothing wrong with the BLON BL-03One thing I did find when using Traillii and Phonix was to give a bit of a gap between moving from one to the other. When listening to Traillii a quick swap makes Phonix sound thicker than soup, while going the other way makes Traillii seem very thin. That’s to my ears of course and it may be a non issue for others. What I tend to do is have a palate cleanser between the two. I normally reach for the Trio, or believe it or not the Blon bl03. About an hour of that allows me to swap one bird for the other.
Needs just a better cable and the right eartips and your fine !
That's actually the pair I bought 3 times and sold 3 times
Totally agree. I think the BL-03 are excellent. I cannot fathom how they sound so good for such little cost. I ditched the stock cable and tips and used the PWA No.5 and Symbio F’s. Turns it into something else entirely. What I like about it in this particular case is how it helps with a bit of brain burn when switching between Traillii and Phonix.Nothing wrong with the BLON BL-03
Monday evening
Nice weather outside
Time listen to these red cherries ...![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
![IMG20220724212437~2-02.jpeg IMG20220724212437~2-02.jpeg](https://cdn.head-fi.org/a/11823799.jpeg)
Amadeo Nospherathu
I'm in business!Monday evening
![IMG_20220725_174557_911.jpg IMG_20220725_174557_911.jpg](https://cdn.head-fi.org/a/11824201.jpg)
Total: 6 (members: 0, guests: 6)
