Oriolus Traillii Electrostatic Hybrid IEM discussion thread
- Thread starter tgx78
I use the Jordivac ( used to be sold by 64Audio, now they have a newer one) with all of my IEM’s. No issue with any. You need a needle that fits the bores and just remove any wax around the bores. It is easy. Do not ever use any force and you will not have any issues.@MusicTeck Andrew, wdyt about the vaac for the bird?
1. Any chance to get a statement from Oriolus about using such maintenance devices?
For a lower price IEM I would just go for it but for the price of the bird I want to be safe
2. Am pretty sure you could sell lots of those vaacs if you take these into your sortiment.
I will be one of the first buyers
Thank you for this! Finally! And I have to say the graph looks as good as it sounds. Smooth, punchy in all the right places, no errant peaks, plenty of air and sparkle. If manufacturers were clever they'd use this as the new target graph for IEMs instead of Harman.I’ve had a lot of people ask me for this, so here you go:
Traillii measurements using an IEC-711 coupler with stock silicone wide bore tips and a comparison to VE Erlkonig #2 that you can use as a reference point.
Thanks for that @aaf evo. Those two BAs man...they're working harder than I am for sure.
