I like them a lot. Much better than the stock pads.
Obviously, someone else’s results may vary from mine. But I’ll try and break it down as I see it.
1. The Brainwavz HM5 sheepskin pads are luxurious feeling, as anyone who has sheepskin pads knows. They provide a tight seal, and the bassiest sound. The soundstage is fairly closed in, which isn’t that big of a deal and expected because these are closed headphones.
2. The HM5 non-angled pleather are similar to the stock pads, and the biggest advantage is more comfort due to the oval shape vs pear shape of the stock pads. The Brainwavz foam is also much more comfortable than the stock pads due to the Brainwavz pads using premium memory foam.
3. I don’t have easy access to my Brainwavz angled pleather pads right now, because my state is on lockdown so I can’t get to them at the moment. Sorry
4. The Brainwavz hybrid velour/pleather fenestrated pads sound excellent IMO. One of my top 2 choices. Same deal as the other pads with regards to comfort, and the big advantage is your ears don’t get hot like they do with pleather. The sound has just the right amount of balance IMO, but bear in mind that I prefer Harman tuning. As expected for a partially velour pad, the low end is more than an all velour pad but less than a sheepskin or velour pad. I think it’s just right. Also, the overall sound with the hybrid pad seems to be very clean and the soundstage is great.
5. The “Senitek fabric” pad is close to the hybrid pad, and my other top 2 choice. This one is a 3rd party (non Brainwavz) pad. It used to be known as the “Senitek Fabric” on Amazon, but I don’t believe they’re available anymore. You can get them directly from Aliexpress here:
They’re great quality, unique material that looks like tweed fabric but feels like a micro fiber suede or synthetic alcantara. Good soundstage and similar sound to the hybrid pad. A very unique pad, and I have a stash of a bunch of them in case they become no longer available. They’ve saved a lot of headphones, and I think they should be in everyone’s pad rolling kit
6. The all-velour pad has the flattest sound of the bunch (as expected), but really isn’t my cup of tea. That’s my personal tastes though, as I don’t like all velour pads on most headphones. It seems to accentuate the midrange a little too much for my liking, making it sound too forward IMO. But I think the reason is because the low end is reduced, so it accentuates the other frequencies especially the peaks that are already present. I’m sure others will like the velour pad though, especially those that feel the Ora is way too bassy and ‘consumer’ sounding.
Final thoughts:
Actually, other than the sheepskin pads, all of the Defean pads are very good quality and equivalent to Brainwavz pads (only at a much better price). I wouldn’t be surprised if they manufactured them for Brainwavz. Good stitching, and they use actual memory foam as well. So if you are looking to pad roll and don’t already have a collection of Brainwavz HM5 pads, order up one of each of the Defean pads.
The bottom line is that pad rolling the Ora is very much worth it, as it allows the sound to be tweaked from stock. I will add that the Ora only has channel indicators on the stock pads. It would have been nice for them to put indicators on the inside of the sliders. I mention it because once you swap to some 3rd party pads it’s easy to get confused about what channel is what. You can always remember that the physical control button is on the L cup and the touch control is on the R cup. Or you can add you own channel indicator, such as a small mark on the slider.
I hope that helps!
PS - you’ll have to carefully stretch the HM5 pads over the stock cups. It’s easiest to start at the pointy bottom of the cup. Put the pad around the point, and then gently work the pad all the way around the cup.
Also note that the back of the pad does cover the 3.5mm and usb C port, so you will have to figure out something for access to those ports. You can just ‘move’ the material out of the way when you need to plug in a cable, or you can trim a little bit of the material away with scissors. It’s just the back portion of the pad so it doesn’t hurt anything. But I thought I would mention it so there’s no surprises.
