Did anyone mod the headband for better comfort with success and would like to share it?
After spending some time to get them properly fitted, the Headband is extremely comfortable for me!
And I was also extremely critical of this in the beginning. You can search my posts here for detailed "before & after" information.
But I have worn these A LOT over the past several months for 5+ hours at a time with no discomfort.
I have an average size head and usually keep my hair fairly short.
I agree. It's waaay too risky trying to bend the headband. If it snaps (like one member), you are screwed.
It's much safer to swap to HM5 pads. It's a very safe mod (no risk), and totally reversible.
It is very easy to bend the headband without risking damage. Just Do Not grab them by the ear cups or yokes when doing so!
Only hanlde the headband itself when trying to collapse or expand the headband.
It's easy and works extremely well. I don't know what everyone is so concerned about? Just use COMMON SENSE folks.
AFAIK there is just ONE reported case of this happening, and it was by an inexperienced knucklehead friend of a member here.
And I believe that ORA sent that buyer a replacement set of headphones after seeing his post here!
