NEVER go from single ended to balanced!!!! It will fry your amp, for sure. To try PM-3 balanced, you need a balanced cable terminated in 2.5mm or 4.4mm male plug. You can then use a 4.4mm female to 3.5mm male to use with regular audio devices.Hi! I have a Khadas T2Pro with both 3.5 and 4.4 mm outputs. I want to try my PM-3 with 4.4 mm. I can just buy a 4.4 male to 3.5 female on AliE and attach the original 3.5 mm to it?
Oppo PM-3 : The Portable Planar - Impressions
W1ll1eTheP1mp
I think you misunderstood. I got both 4.4 mm and 3.5 mm inputs on the Khadas T2Pro. So if i plug in a 4.4 cable with a female 3.5mm in the end to connect my Oppo PM-3 with 3.5 mm cable? Shouldn't that be exactly the same as the people who pay quite much for the 2,5mm to 3.5mm cables for Oppo PM-3?NEVER go from single ended to balanced!!!! It will fry your amp, for sure. To try PM-3 balanced, you need a balanced cable terminated in 2.5mm or 4.4mm male plug. You can then use a 4.4mm female to 3.5mm male to use with regular audio devices.
megabigeye
You can use a cable that’s 4.4mm TRRRS on one end and 3.5mm TRRS on the other.I think you misunderstood. I got both 4.4 mm and 3.5 mm inputs on the Khadas T2Pro. So if i plug in a 4.4 cable with a female 3.5mm in the end to connect my Oppo PM-3 with 3.5 mm cable? Shouldn't that be exactly the same as the people who pay quite much for the 2,5mm to 3.5mm cables for Oppo PM-3?
You CANNOT use a cable that is 4.4mm TRRRS to 3.5mm TRS. This will create a short within the Khadas.
Edit to add: the PM-3 is wired internally to work with either TRS or TRRS.
peterinvan
If you use the balanced out TRRS you must use a 3.5 TRRS balanced plug at the headphone socket. Else you may short circuit the amp output. Here is my example with a 2.5 TRRS balanced plug.I think you misunderstood. I got both 4.4 mm and 3.5 mm inputs on the Khadas T2Pro. So if i plug in a 4.4 cable with a female 3.5mm in the end to connect my Oppo PM-3 with 3.5 mm cable? Shouldn't that be exactly the same as the people who pay quite much for the 2,5mm to 3.5mm cables for Oppo PM-3?
Here is a 4.4 cable on ebay:
https://www.ebay.ca/itm/18373858660...7sPrpwo02zS61I8BA%3D|ampid:PL_CLK|clp:2334524
W1ll1eTheP1mp
So what i need to make it work with the Khadas is 4.4 trrrs male and 3.5 trrs cable? So to make it work i have to use a 3.5 mm trrs into PM-3?You can use a cable that’s 4.4mm TRRRS on one end and 3.5mm TRRS on the other.
Keep it simple. A 3.5mm TRRS from the headphones will give you balanced signal at the other end, in your case 4.4mm. A 3.5mm TRS from the headphone will only be good for single entry signal. Using such a cable will blow up your DAC if plugged in the balanced port.
megabigeye
Yes, something like this.So what i need to make it work with the Khadas is 4.4 trrrs male and 3.5 trrs cable? So to make it work i have to use a 3.5 mm trrs into PM-3?
EricDH
That is a very nice feature of the PM-3. I have a cable with one end TRRS and the other end XLR, so I can benefit from the balanced output of my Jotunheim.Edit to add: the PM-3 is wired internally to work with either TRS or TRRS.
voicemaster
Still enjoying my PM-3. Bought new when it was released and I just changed the earpads with sheepskin leather earpads which is better than the original pads.
EricDH
I replaced the ear pads too. But now the head band has started to (seriously) deteriorate (leaving some black dandruff after listening). So I may want to replace that too. But it looks like a much more difficult thing to replace than the pads.Still enjoying my PM-3. Bought new when it was released and I just changed the earpads with sheepskin leather earpads which is better than the original pads.
Rub all that black stuff off with care and you're left with a nice gray headband. Buy a zippered headband cover to protect it and you're set. Not an easy task replacing it, not worth the trouble if you ask me.
voicemaster
Yea for the headband, I will just peel off all the black stuff away and use a zippered cover over it. I have already bought mine (cover) eventho my headband still pretty intact.
magicalmouse
Where do you get these?Buy a zippered headband cover to protect it
d
Ebay, aliexpress... They're everywhere, really. Cost only a few dollars, too. For instance:
https://www.aliexpress.com/item/4000268646601.html?spm=a2g0s.9042311.0.0.27424c4dm7DnrQ
EricDH
Will look into that.Rub all that black stuff off with care and you're left with a nice gray headband. Buy a zippered headband cover to protect it and you're set. Not an easy task replacing it, not worth the trouble if you ask me.
Total: 6 (members: 0, guests: 6)
