So which replacement earpads that didn't change the PM3 original sound?
Oppo PM-3 : The Portable Planar - Impressions
voicemaster
https://www.amazon.com/gp/product/B0869JD3C6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1So which replacement earpads that didn't change the PM3 original sound?
I bought this from Amazon and the Black Sheepskin leather is better than the original pad.
better at what?https://www.amazon.com/gp/product/B0869JD3C6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
voicemaster
Better material (fake vs real leather) and I don't hear any difference with the original pad. Pokoknya qualitasnya lebih bagus daripada yg asli.better at what?
Are you Indonesian?Better material (fake vs real leather) and I don't hear any difference with the original pad. Pokoknya qualitasnya lebih bagus daripada yg asli.
![Grinning face with sweat :sweat_smile: 😅](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f605.png)
voicemaster
YeahAre you Indonesian?![]()
Any ideas for cleaning/washing the denim case?
Why does my PM3 sound so bright and metallic? Using sine swept I hear high peaks in the 7k-9kHz area. Bass is also very weak. Isn't the PM3 supposed to have a smooth and slightly dark sound?
Must be something wrong with your set. I have 2 and they are both smooth and rolled off in the treble. I wish they had a but more highs.Why does my PM3 sound so bright and metallic? Using sine swept I hear high peaks in the 7k-9kHz area. Bass is also very weak. Isn't the PM3 supposed to have a smooth and slightly dark sound?
How I feel with my PM3, exactly like this review https://www.soundstagesolo.com/index.php/equipment/headphones/71-oppo-digital-pm-3-headphonesMust be something wrong with your set. I have 2 and they are both smooth and rolled off in the treble. I wish they had a but more highs.
Sound trebly
Chris Kaoss
What's about listening to music instead of sine sweeps?Why does my PM3 sound so bright and metallic? Using sine swept I hear high peaks in the 7k-9kHz area. Bass is also very weak. Isn't the PM3 supposed to have a smooth and slightly dark sound?
![KSC75 Smile :ksc75smile: :ksc75smile:](https://cdn.head-fi.org/e/headfi/ksc75smile.gif)
Joke.
At which volume level do you think the PM-3 is going to be fatiguing while listening to (what kind of) music?
Never experienced a metallic sound from my set. Even with the brighter V30 and BTR5.
This is what I've heard from some Focals, but not Oppo.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
With music, I heard the hihat and chinese cymbals too hot. Using sine swept only to determine what frequency is excessive.What's about listening to music instead of sine sweeps?![]()
Joke.
This is what I've heard from some Focals, but not Oppo.![]()
Problem solved! It's all just a matter of fitting. My head and ears are so small that my entire ear actually fits into those tiny PM3 earpads.
When I wear it without lowering the headband, that dark sound appears. Bass rises drastically, metallic sound disappears. And the more I lowered the headband, brighter the PM3 will sound.
Metallic sound came when I lowered the headband until my ears were completely inside the earpads.
I analogize this like as listening to speakers up close. The more we turn our ears up, the more we hear the bright sound from tweeter.
tinyman392
Be nice to noobs, we were all noobs at one point in our life.
- Apr 27, 2011
I never really found the PM3 to be smooth and dark. I remember reading that about the PM1 and PM2 though. To be honest, the PM3 sounds pretty neutral with the slightest bass boost to my ears. I do know mine are authentic since they were a review sample from way back in the day.Why does my PM3 sound so bright and metallic? Using sine swept I hear high peaks in the 7k-9kHz area. Bass is also very weak. Isn't the PM3 supposed to have a smooth and slightly dark sound?
That review is the opposite of literally anyone else who has reviewed them. Almost universally, people wish it’d had better treble extension. They also aren’t rattle your head kind of bass, but the quality and quantity of it is good. Very clean, planar bass.How I feel with my PM3, exactly like this review https://www.soundstagesolo.com/index.php/equipment/headphones/71-oppo-digital-pm-3-headphones
Sound trebly
Replaced my earpads and problem solved. PM3 is very sensitive to seals. A slight leak can reduce the bass, especially when using worn-out earpads.That review is the opposite of literally anyone else who has reviewed them. Almost universally, people wish it’d had better treble extension. They also aren’t rattle your head kind of bass, but the quality and quantity of it is good. Very clean, planar bass.
