newyorker4life
- Jun 1, 2016
I was hoping to start with pm3 and no DAC, just iPhone. Having just read the entire Meze thread I'm scratching my head now.
Depends on the type of music and genre you listen to. I have no issues with PM3 + mojo using USB Audio PRO via Android with EQ
... I spend 600 eur of pm3 ..the same for the mojo and some other for transport ...result use an equalizer to make them sounding well ... mmm . Do you think something is odd ?
I see for some audience here I would be in a kind of wrong way...
I have replaced mojo with dx 80 ... more neutral ...Less stuff to bring and, mainly more power.
I found PM3 really sensible to presence of watts (the Grado for instance they are not) and I found also oppo really sensible with cabling.. unfortunately these are really difficult to rewire internally
When I speak about 8000 milli watt amplification is not of a portable amping I refers to and oppo gains in scene size (the oppo dark side I would say)
In all these case I never use the EQ regardless we are speaking of vocal jazz, electronic classical or jazz
It is a countersense with me ... It's a way to "force" ... especially with headphone
EQ is on my opinion something to adapt sounding system to the environment: we would have sound differencies between rooms becouse of sound reflection, in absolute I do not use EQ to make tracks better sounding and since linked with environmental issues EQ is a non sense with headphones
Just arrived. Burning in. Anyone notice much change with burn in? If I don't like cans before burn in, I don't like them after. If they are good, they can improve. Detail is incredible. I'm sensitive to highs, they are just slightly bright to me, any less of that reported "roll off" would be too much. Mids are full, yet no ringing resonance. The low mids are flat and perfect as is mid bass, aside from a small bump. Sub bass is definitely there, and extends well, just not quite loud enough. Ideally, that would be 2 db higher at 20 hz.
Fit is good. Despite being portable, on a little wider than average and a lot longer than average head, they reach. That's always the biggest issue for me (how much the cups extend). A bit of clamp, but I'm able to flex them to ease that. The pads are deep enough so my ears barely or rarely touch and fit top to bottom. Padding is narrow, meaning it puts pressure on a narrow area. If they were thicker (not depth) there would be a better spreading of pressure. It would also improve the seal and isolation. More on these later.
The description of 'fit' here is the best I've read in the thread. I'm tall and have a somewhat 'long & slim' facial profile. It's interesting that there are so many different opinions about using the PM3s with/without separate DAC. The PM3s are supposed to be 'portable' .... and to me that means only using my iphone as music source. $600 for a Mojo or $1,000 for a separate digital music player is a bit much for me.
I was around 60-70% from Iphone 6
Amplification is not essential. I enjoy my PM3s straight out of my iPad. 50% volume is loud enough. SQ is very enjoyable. Listening to Tidal HiFi (Jazz and acoustic music mostly).
Albeit, driven by my CEntrance M8, at high gain, the PM3s improve in bass taughtness, and midrange clarity. I am also able to play with the EQ settings on the M8, when a particular track needs a bit more treble, or a bass boost.
