dennistdk
- Aug 9, 2015
I need help with this too
It only shows as 16/32bits on OSX (I know the Oppo specs says 16/24/32).
However is that really a problem? Setting it at the highest bit depth (32bits) will always be preferable no matter the (lower) bit depth of your source - you should however always match the sample/bit rate of your source file.
Going for a higher bit depth doesn't make it loose quality, but you gain better resolution if you are not running at 100% volume as you won't "loose" bits.
I usually run it at 44.1/32bit as my source is mainly Tidal lossless at 44.1/16bit.
