I really like this set. It comes with 3 short cables (micro usb, mini usb, and 30-pin) for $8 w/ free shipping if you have Amazon prime. You can use the micro usb cable to charge the HA-2 as well.
http://www.amazon.com/dp/B003T5KXJQ/ref=sr_ph?ie=UTF8&qid=1435271000&sr=1&keywords=30+pin+usb+short
I have a brand new MacBook Pro 15-inch ... With both OS X and Windows 8.1 (soon to be 10) via boot camp. What is the best way to get this set up for music? I have the HA-2 and PM-3 but I'm going to see about other products too. Eventually get a full size headphone setup and speakers for movies.
I use the Kero Nomad Cable.
http://www.amazon.com/Nomad-Cable-Apple-Certified-Lightning/dp/B00E9B8V5M/ref=sr_1_2?ie=UTF8&qid=1435117700&sr=8-2&keywords=kero+nomad
And Onkyo HF Player to play flac files on the iPhone 6.
I originally bought this to use my iPhone with my CEntrance M8, but the M8 was pretty big - the Nomad Cable is really stubby and doesn't add a lot of length to the stack, so since there isn't a proper 90 degree solution, I am pleased with the Nomad's performance - and it is stable enough (IMO) to put the stack in my pocket, Lightning end first.
Hi All, I'm a newby here. My HA-2 now is on the way to me and I'm wondering how good it will be with my HD650 (300 Ohm). Is its output power at 300 Ohm enough to drive them well? Also planning to use it with Vsonic GR07 MKII.
