Glmoneydawg
someone who wants to put a horsepower rating on their system!Who runs a high end audio system off a gasoline generator?
If voltage from a generator is destroying electronics, then it will also destroy that UPS. Electronics already have the same AC line power supply also found in electronics. And neither are in as much danger as motorized appliances.I will be sure the ups is better than that old gen belching smoke.
Its not a voltage problem...the vfd uses the 60hz line frequency as a reference...most generators frequency will fluctuate with changing speeds/loads ect which it corrects quickly....not a problem for most household stuff,as long as 100% stability isn't required.If voltage from a generator is destroying electronics, then it will also destroy that UPS. Electronics already have the same AC line power supply also found in electronics. And neither are in as much danger as motorized appliances.
Better is to put that UPS on what is at more risk - ie dishwasher, refrigerator, and furnace.
To make robust electronics far more robust than a UPS, replace its power supply with a universal power supply. Same supply that comes standard in portable electronics.
Address a problem by first identifying that problem. UPS is a solution for a problem that was not defined. And now that it is defined, UPS is only another potential victim; not a solution. As made obvious by recommending without citing even one specification number.
Back in the early Carver amp days. Pros would try to power the amps from a generator and of course the generator would lose it's mind. Same type of problem (sort of) when trying to power a big amp with a SMPS from a UPS or generator.my business does variable frequency drives for industrial applications...digital tech has made these much cheaper and reliable recently....but if you run them off a generator they loose their minds...very hard to maintain stable 60hz (canada)line...so i would be leary of running fancy electronics off them.
