opinions on the DT770 '05 600 ohm?
Jul 12, 2010 at 6:26 PM Post #136 of 150
Any suggestions of some OTL Tube Amps? Not framiliar with OTL at all, only tube amp I have ever had has been my Little Dot mkII
Jul 12, 2010 at 8:25 PM Post #137 of 150
What price range?
Jul 12, 2010 at 8:29 PM Post #138 of 150
well about $200-250 max I guess, I would consider selling my LD mkII if this amp would be superior which would add maybe another $120 or so I think.
Jul 12, 2010 at 8:34 PM Post #139 of 150
In that case I will suggest the Darkvoice 336 - works well with those headphones, and is in that general price range (that's about the lowest you will find for a decent tube amp).
Jul 12, 2010 at 9:26 PM Post #140 of 150
Around $200 only? Hrm... maybe some Darkvoice amps would be in that range, but you should save up and go for a OTL Woo Audio amp of some sort.
I heard the DT880's on the MKII and did not like it's sound at all. It sounded off to me. Maybe the MKIII would be better buy I have not heard my phones on it so I can not comment.
For a taste of tubes, get a PHENIX G3 or G7. Both are sub $200 and will drive them nicely (but don't expect them to be driven to their full potential). I had the G3 version and it sounded great with my DT880.
EDIT: Fixed typos.
Jul 12, 2010 at 9:35 PM Post #141 of 150
I can certainly vouch for the MKIII.   Pair these up with the right combination of Mullard/Sovtek tubes, and any 600ohm beyer models will sing. Frank_1 and Marouzen have no problems running their T1's off the Mark II,  you might wanna tube roll a bit to see if the sound becomes to your liking. Getting a better source helps as well.
Jul 12, 2010 at 9:40 PM Post #142 of 150
Thanks for the advice so far everyone, more than anything I was just trying to get some background info on possible amps for the dt770 assuming I got that route which is dependent on my dt990 250ohm selling. I might give some tube rolling a shot with the mkII, wouldn't mind a new amp but at the same time there isn't anything I find clearly wrong with the mkII. So far it has been awesome aside from the included RCA cable dying a very early death for no real reason aside from it seemed to feel like it.
As for source, I'm considering/looking into budget cd player's right now, hoping to find something solid for around $100, if that is possible I will jump on it no question.
Jul 13, 2010 at 12:35 AM Post #143 of 150
Get an Oppo universal disc player, I think they sound very good for the money. There's one out there for $169 I believe. It's in my MusicDirect catalog.
Nov 15, 2013 at 2:41 AM Post #144 of 150
finally snagged a dt770/600 once again, slapped on the alpha pads, plugged it into the DV336se
and this baby sings like a lark. very very satisfied with this forgotten gem.
( i know this thread is forgotten too..anyway do try the alphapads :p )
Nov 24, 2013 at 2:24 AM Post #145 of 150
Interested on what's the difference of it with the alpha pads? compared with the normal velour pads
Feb 6, 2014 at 5:29 PM Post #146 of 150
I thought I was going to be the first to try this, apparently not. I just got my DT770 600 ohm Premiums in the mail today and was curious if the Alphas I'm using on my D2K would fit or not. I'm glad they will!
Feb 9, 2014 at 10:43 PM Post #147 of 150
One tip that I found make a huge difference and easily rolled back. I removed the foam in front of the driver. Not really needed since alpha pads has it's own driver cover built in. It makes the sound much more open, clean and better clarity and details
Feb 10, 2014 at 6:25 AM Post #148 of 150
I actually ended up taking the Alphas off. I own a Denon D2000 and will just use the Alphas on those. I'm kind of liking the mids of the DT770, and the Alphas take them away from me. The only real plus to having the Alphas on them was the increased bass response, but if I want bass I'll just listening to the D2K.
Apr 13, 2014 at 11:41 AM Post #149 of 150
Since my last post, i actually took out the alphas, and had been listening to the stock beyerpads.
But two nights ago, whilst tweaking my other cans, i reinstalled the alphapads onto the DT770/600ohms...
and i distinctly heard a bigger soundstage that sort of went "outside, beyond"  the cups...!?
Dun think the alphapads are going anywhere..its on permanent duty with the DT770 :p
hmmm....didnt suffer/miss the lost of the mids on my setup, been swapping tubes on the dv336se to notice it :p
A Raytheon 6AS7 is sending my alphapads reverberating to some phrrrrooompy classicals.
seldom use the dt770 for vocals..
she sounds glorious n upfront, with a big deep wide orchestra around her .
Jun 25, 2017 at 3:50 AM Post #150 of 150
old thread, but I love my dt770 - 600 ohms. I don't know what year they were made, but they are the best headphones ever for using with my tube amp. Much better than HD650's because they 1. isolate better, blocking out unwanted external sounds 2. actually sound more realistic than the Senns and they have a huge soundstage for a closed headphone. Bass is not exaggerated, it is perfect. It appears they don't make this model anymore?
