Originally posted by CRESCENDOPOWER
See, that's the part you don't understand all headphones have certain traits, and just because a phone sounds brighter, faster, and clearer with lower level equipment certainly doesn't qualify it as having the ability to better tell the differences between amps. |
I understand this quite well thank you very much, but the same applies in the reverse, just because a headphone has a high impedance doesn't qualify it as having the ability to better tell the differences in amps.
Oh, a by the way, not everyone on this site thinks the HD-600s are veiled. |
I suggest you reread what I said. Yes there are people that have overcome the veil or even those that don't hear it at all, but I suspect there are quite a few more than that who do hear it. It's just that anytime someone mentions anything against the 600's the fanatics come out of the woodwork to staunchly defend their precioussssss, and start these stupid little wars. It's just not worth it so people keep their mouths shut.
If you want facts, the facts are the better the equipment you through at the HD-600s the better they sound |
Is there anywhere that I said differently? In fact that's about exactly what my point was, but just because they sound better with better equipment doesn't make them the best headphone to distinguish amp differences. I'd be willing to make a bet that my setup would sound better with upgraded equipment as well. That's the nature of better equipment. The difference is, in my situation I don't feel the need to upgrade to overcome flaws I perceive in the headphone. But that has no real bearing on which headphone is best to tell differences in amps.
If all these ridiculous low impedance extremely bright phones that are comming from Audio Cubes are so "trasnsparent" why is everyone buying the RKV, and impedancer to hook up to them? Wouldn't they buy a more "neutral, or transparent" amp for them?
You know, an amp that would tell them more of the "truth". |
If you prefer your phones mired in mud, plodding along not able to keep pace, keeping you at arms length from the music that's your prerogative. (Ok, so I'm exaggerating a bit
) Just because you don't like these so called bright headphones doesn't mean they aren't revealing and it doesn't mean they are bad headphones. I would assume that people would buy the RKV because they like the sound of it, everyone has different priorities in sound. Personally from the descriptions the RKV doesn't really interest me. I'm far more intrigued by the EMP. Not everyone is looking for a completely neutral setup, some like tubes, some like the solid bass of good solid state. These are just generalizations but I think you get what I mean. Everyone has different priorities.
So, my questions are, why is so easy for me to tell the differences between tube swaps, cable changes, amp changes, and source changes with the wooly sounding HD-600s? |
I’ll reply to this as well.
I'm quite sure the HD580/600's will reveal differences, especially after a cable upgrade and when the equipment is of higher quality or better match to them. Does that mean they are the "best" at it? No, I personally think there is probably better out there for that.
