caenlenfromOCN
I've been taken care of the on the 3D printing. Thanks!
Please make a video of it when you actually assemble it all, I may do it, I just need to see it happen step by step as I am a visual learner.
Shouldn't be too hard to edit the files if the original CAD files are uploaded. I am hoping to do some extra design stuff on the outside of the cups myself on those files too... Modifying the .stl´s would probably be painful, though.
If you still consider connectors then I guess I found sources for the Hirose jacks. If I guess correctly, then Hirose HR10A-7P-4P and -4S should work. Can be found on Mouser, Digikey. Aliexpress should have a set for around 8$
http://tinyurl.com/hdbrjaq
Important note: I haven't tried them myself yet, it just seems to me like they should fit. Double and triple check before buying, or wait for someone to report back if they work or not
They look great already! How did you finish the cups? Also, did you use the Hirose connectors? Any suggestions where to source them?
Many thanks in advance for any insights you will be sharing on your experience so far! Thanks!
What is the benefit of using a Hirose connector rather than a standard connector? I think it would be easier to fit Mini-XLR or female 3.5mm ports on each ear, but only due to not finding any information about the Hirose online. I could only find a couple niche forum posts from a couple years back, and from what I read it sounded moderately difficult to properly solder a Hirose port. I'm decent at soldering, but by no means a complete pro. Any info greatly appreciated, thanks
Hirose clone connectors are available from Mr. Speakers himself as he stated earlier in this thread. I bought a set from his website. They are also available from ali express as another member posted earlier in this same thread.
