Arty McGhee
- Apr 14, 2014
Kk ABS it is....
I have a few different pads I will try out... And if I really like how they turn out, ill probably rebuy whatever pads I leave on them... I decided that I would go with a 2.5mm connector, I can get two male and females for 5 bringing this whole test project to $35. Im hoping that they turn out well and I won't break the bank trying.
Just gotta edit the file to make the hole smaller
pla is easier to print, i have a bunch of abs and i'm going to start with that, there are all kinds of new pla + type filaments out there best to do some research
i'm doing something similar, i have 3 headphones set up to take the 2.5mm plug, it will be simple to mod the cup in tinkercad
i may make a plug to fit the existing hole and the jack for a 2 tone look
printed the baffle and pad ring in abs, came out great, looks like its made to fit the alpha pads, and hm5 pad will not fit
you may have to do some tweaking to that file also
going to start the cups tonite
