Tuluum
- Jan 27, 2017
Does anyone have some feedback on how they feel the waveguides affect the headphones? I am pretty curious about them, but have been focusing on my amp ever since I got my bass response sorted.
For those complaining a bit about the low end, I have to admit that I found the same issue initially. I do tend to like a bit more than most, I suppose. I found that any type of material on the back of the driver (like with typical mods, stiff felt, etc.) didn't work out too well. I also found that having a nice solid "glue job" of the foam to the inside of the cup was important. Overall, the volume inside the cup can increase the bass response pretty dramatically with relatively small changes like thickness of damping material and making sure its glued down everywhere. I tried a lot of different cotton/wool type fills as well, and found that going completely without was worse. The amount I ended up with was.. maybe about 1 cotton balls worth fluffed furiously. No scale, so nothing more specific than that.
Not necessarily bass related, but I have found that foam attacked to the ear side baffle as well as the interior baffle yields a nice sound. I also bored my ports out to 1mm. I figured if I didn't like it, I could just seal some of them up to compensate, but, I dig the change.
Of course, the obvious stuff like proper seals should also be considered, but if using anything like foam between the baffle and cup, its good to make sure its really quite thin. If its on the thicker side, it can cause some of the screw posts to snap off under the pressure (even if holding them together, ask me how I know ). The material I tried initially compressed down to ~.8mm but still gave some issues.
