Tennessee
- Sep 16, 2014
Out of curiosity - are you able to set one of both SD cards in tidal as a saving place? I get only SD1 showing up.
Yes, just one SD1.Out of curiosity - are you able to set one of both SD cards in tidal as a saving place? I get only SD1 showing up.
And so... when it comes down to it... if you can't hear the difference... then does it matter? (Aside from the possibility you may be paying money for stuff you can't actually hear. )
Hi
What is the advantage of a DAP being rooted ?? There are apps to uninstall unwanted apps, onto a small SD card,, so if any are needed in future you can reinstall from card. The large 200GB + can't you just put them into slot in Macbook and load your wanted tunes onto these. I have read a lot of messages on this forum and it makes the DPA - 1X sound like a difficult DAP to use, not just to take out of the box and use. And would this item make a unbalanced IEM into Balanced one, https://www.amazon.com/gp/product/B0108HJVG8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thanks for the link but unfortunately they had sold out, not sure if the vendors make any of it products it sells. So basically the $25 adaptor wont work , and do you think the replacement cable could be made into a balanced cable.
kind regards
Barry
P.S. can you put tunes on SD cards by putting in mac sdxc slot
Hi
I wrote an app specifically to do transfers from OS X to DAPs and in fact an OnkyoDP-X1 is my primary device.
You can test it out by downloading it free at https://www.map-pin.com/dapper/
Hi JeremyHighly recommended. My DP-X1A loves Dapper.
It does USB or direct cards plugged into the Mac.Hi Jeremy
Is the app for usb transfer only
I'm pretty sure Tidal is using all x1(a) goodies, since having the same album from CD and Tidal they sound the same (tried on three 1000€+ headphones) and all setting changes made in onkyo music app are live even when listening to Tidal app (DAC filter type, upsampling). Sometimes you can find albums that sound differently, but then it's becouse tidal's post processing or their source (so "fault" on tidals side).
