headwhacker
- Sep 4, 2013
I hear you on the fragility of MMCX, it's a very real thing.
I was thinking of buying a balanced cable and then use a 2.5mm TRRS to 3.5mm TRS adaptor if I need to connect to a single ended. Will see, so far I'm only using single ended, but there are a couple DAPs with balanced outputs eyeing up my wallet.
That is all you need. to do and don't have to worry about MMCX connector.
