ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Jul 6, 2016 at 12:03 PM Post #10,006 of 16,376
A day will buy a dp x1, I will use it only in SE should I onkyo or pioneer XDP-100r? in SE they have the same sound or onkyo is better?
It depends on the DAP too. I do not owe the Pioneer CDP-100r. However, if you choose to have (or already have) an external amp I would say DP-X1 won't be disappointed. For example, I am listening to the 2 combinations DP-X1+ Mojo and DP-X1+ Theorem 720 via SE connection (IEM and HP). They all have excellent SQs.
Jul 6, 2016 at 12:30 PM Post #10,007 of 16,376
there is much difference with dp x1 with or without mojo?
Jul 6, 2016 at 12:57 PM Post #10,008 of 16,376
The difference will be the relative difference in sound signatures, so yes there will be a noticeable difference. If you are using the DP-X1 as a digital source only to feed the Mojo, which you would be doing, you will only be hearing the sound signature of the Mojo. Frankly unless you need something the DP-X1 offers fine, but any smartphone with the correct digital out will be as good a source to feed the Mojo. When used with the Mojo you are hearing the Mojo.
Jul 6, 2016 at 2:14 PM Post #10,010 of 16,376
To my ear is a yes. Adding an external amp like Mojo or T720 would give the musics more layers of decay with SE compared to ACG balanced out.
I would assume nobody would use the Mojo just as an amp, they would use it as an amp and DAC would they not?
Jul 6, 2016 at 4:36 PM Post #10,012 of 16,376
Correct.
You can't use the Mojo just as an amp. For one the Mojo only has digital input. Two, the analogue out isn't like most gear with a separate amp section. The very simple OP stage is tied directly to the DAC with discrete components and is more like a variable line-out from the DAC than a seperate amp section. Because of the very good noise performance straight out of the Mojo's Pulse array DAC they can do this, unlike most other DACs chips that have the I/V conversion, then the low pass filter, then the voltage amplification and current amplification.
Just posting because it was raised in the thread, sorry for the OT.
Jul 6, 2016 at 9:59 PM Post #10,017 of 16,376
ah...the shop i like to get dp-x1 is having 10% off for member price around usd665....so the price is quite attractive now.
they didnt sell the pioneer one.
i am using UM Mentor currently.
