ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Jun 29, 2016 at 4:32 PM Post #9,781 of 16,328
Wow ... it's been busy here over the past week while I've been away at Glastonbury.
As fantastic as that was, it was also nice to get back to the clean comfort of my train carriage this morning, with my DP-X1 and T5p to entertain me
Great to see the community of users growing.
Jun 29, 2016 at 5:20 PM Post #9,782 of 16,328
  Checked both, but no luck so far! Wondering if it is in a hidden folder or something
I suspect it is embedded in the Onkyo Player's proprietary file index and not exportable. The Onkyo player app needs its' own file index so that your tracks and playlists can be played immediately after powering on. Otherwise, it would have to wait for the painfully slow Android system re-indexing of all media files on SD cards each time it powers on. I am an extreme case, but it take s a good 30-40 min for Android to index 10K files on my SD cards. You can also see how bad this is by loading an M3U playlist file in the Music directory. It takes a long time for the playlist to even display in the Onkyo player every time you power on the X1 because all the files have to be re-scanned before the M3U files get processed. Again this happens every time you power off/on. The work around to this is as follows:
1) Create M3U playlist files that match the directory structure of your SD card
2) Copy M3U file(s) to the SD card
3) Wait for the painfully long time for the playlist with all the tracks to show up in Onkyo player
4) Once it is fully scanned and available, play track 1
5) Got o view play queue
6) Save the entire queue (your M3U playlist) as a new playlist in the Onkyo app. do this for each M3U file.
7) Delete your M3U file(s) from the SD card
8) Now you can play the playlist immediately after power on instead of waiting forever
Jun 30, 2016 at 1:13 AM Post #9,783 of 16,328
Have any of you had battery problems with this player? Mine was working fine until yesterday but now the battery drains in 1 hr and 30 minutes. It is supposed to last 16 hours so obviously something has gone wrong, either with the settings or the battery has just gone bad. Player had been working great up until this started and had not been dropped or had any settings changed. Any idea what might be going on here? I hate the thought of the hassle of returning this item.
Jun 30, 2016 at 1:23 AM Post #9,784 of 16,328
1. Go to application and disable notification of each app.
2. Some apps you do not use often, disable the app (you may enable it any time later).
3. Go to the Notification option, suspend all notification.
Jun 30, 2016 at 4:02 AM Post #9,786 of 16,328
Hihi!~
I am facing a little issue now.
Sometimes my DP-X1 stops playing even though there are still songs in the Q.
It stops after a few songs, sometimes 2 songs , sometimes is ok(all songs in Q played)
Any idea what went wrong? Some settings?
Jun 30, 2016 at 7:45 AM Post #9,787 of 16,328
My experience is that the only thing that reduces my battery usage to zero overnight is to leave the X1 on stand alone. This disables all android background activity. If you try this and battery discharges o/n there is a battery problem. If there is no drain then as already suggested there is a background(s) task running.
Jun 30, 2016 at 9:11 AM Post #9,788 of 16,328
Good morning, any of you who has the dp x1 has tried with headphones grado 225e? I would be happy to know he his impressions.
Thank you.
I tried dp-x1 output to a desktop tube amp (via Line out) to drive Grado sr80e. The result is impressive.
Jun 30, 2016 at 9:24 AM Post #9,789 of 16,328
This works - Power button to volume button app.
Tried it this way: listen to music in stand alone, screen off. Turn volume control screen comes back on.
Let screen time out - turn vol control and screen comes on.
Now I have my wonderful Dignis case I hope I never have to use the power button again!
Now that is a neat trick!!!
I also apologise for my small absence, lots of things going on irl...
I have spoken to my contacts within Onkyo regarding actual screen tap on/off, as well as lock screen widgets and/or music info on lockscreen. All has been passed on to the Onkyo DP-X1 development team.
No promises if anything will come from this, but I'll let you all know on any progress.
Jun 30, 2016 at 10:43 AM Post #9,793 of 16,328
    Dear Sonic Defender and TheOneInYellow:
    Your collective points are well taken regarding the "flat"/non-eq'd ONKYO DP-X1's sound signature...no specific reference DAP equals no valid comparison...and as it was several days ago that I was doing my initial research regarding the DP-X1 as a potential DAP purchase when I encountered the writer's expressed concerns regarding said DAP, I cannot recall which user I noted, nor do I recall if (s)he specified another unit as a reference point, (curve?...).
    My preferred listening frequency curve tends to look/sound like that of the Sennheiser HD-650's/circa 2007, (warm/lush lower mid-range/mid-range), and/or the Audeze LCD-2's/pre-fazor, (relatively strong sub/deep bass), (ideally incorporating both the LCD 2's bass and the Hd-650's midrange), driven in balanced mode by a Schiit Audio chain of an Yggdrasil D/A converter and Ragnarok amplifier for what it is worth...   However
  I am quite unlikely to be playing those headphones with the DP-X1, (or any other DAP for that matter), such that, for at least the reasonable future, I might be driving a pair of V-MODA M-100's with said DAP...and would like to know how THAT combination might sound relative to MY ideal sonic reference...
  I did note after doing some additional research on this thread that there were indeed more than a few expressed concerns that the DP-X1's EQ system does not seem to "scale well" relative to several other DAP models...however, I am not attempting to turn the Onkyo model into a "bass cannon", but simply to perhaps better emulate the sonic signatures of some rather well thought of headphones...
  If amplifying the frequency ranges that I would prefer to be a little bit stronger might cause digital(?) distortion due to relatively minimal digital headroom, how much sonic degradation might I experience by simply reducing the levels of those frequency ranges surrounding those ranges of which I want to hear more...Would I experience a very significant reduction in signal to noise levels, or some other form of distortion...?...
  I am still genuinely interested in this DAP, (it has MUCH to offer), and am simply looking for viable solutions to what may, or may not be a concern...your input is valued!
Thank You
Peace
I think a lot of Head-Fi'ers have replied back to you in my short absence.
First things first, this is just some extra info for everyone: flat frequency is NOT neutral. That is just a mathematical ideal. Though everyone has an idea of what neutral is, neutrality is usually very small increases in specific areas of a frequency range so that various sounds sound 'natural' to human ears. Etymotic and Phonak almost got that right with their earphones for example.
Musicality is different; this is where we humans prefer to hear something fun, in specific areas of a frequency range.
Though recorded music is one thing, it is near impossible to replicate it as neutral, so yes, one could try to playback the recording as recorded, but as neutral is different to everyone, flat-frequency is not the answer. Of course, many of us like to hear a recording the way we like to, and will get gear to do just that.
Therefore, to me I think the the DP-X1 is extremely neutral with small emphasis on coherency: speed of transients, a very small bump in mid-bass, ever so slightly upper-mids, and extended treble but not as sibilant as I expected.
This is my impression using the DP-X1 in high gain, ACG balanced mode, with my Audeze EL-8 Titanium headphones and DHC Molecule Elite 22 Silver (22AWG) 4-Wire balanced cable.
When I tested my Meze Headphones 99 Classics (normal gain, unbalanced mode) with stock cable, the DAP sounded different; warm, musical, a tad indistinct in bass yet still lovely. I attribute that to the DAP having little sonic colourisation.
Ditto same experiment (high gain, unbalanced) on my AKG K 712 with DHC Molecule Prototype 25AWG copper cable; heard some sibilant peaks, slightly spotlighted vocals/mid-range, and clear bass notes but not much oomph.
My Heir Audio 4.Ai IEM's (normal gain, ACG balanced) with DHC Molecule Symbiote Fusion 8-Wire balanced is very similar to the AKG K 712 but less soundstage, less coherency and more focus on individual instruments or sounds.
In many ways, the DP-X1 is not a 'warm' or 'tubey' DAP, which is why some users opted for the Astell and Kern or Questyle QP1R.
So, with that in mind, because of the neutralish sonic character of the DP-X1, it allows each of my headphones to display their own characters.
Thus, any headphone you plug in will sound great on this DAP, as the DAP does not colour the sonic picture too much or at all (in my opinion).
What the DAP does do is give excellent clarity, hardly any grain, amazing detail and texture, great soundstage in height and depth (though more width would have been nice), and is super fast on transients.
Regarding EQ, as @Laird has said in his post (here), one should never boost, just cut/attenuate. By boosting you massively reduce headroom and dynamics, but reducing frequencies, the dynamics are impacted upon less.
This is something I learned from when I studied Music Technology years ago and did PA work.
Having said that, I echo that the EQ on the DP-X1 may not scale well if boosting, it clips, but that is as far as I can comment upon as I do not use EQ on the DP-X1.
I think the DP-X1 is stellar and worth investing in, but only a demo of it can really tell you the truth.
If the DAP does not sound right to you, I strongly recommend Questyle QP1R, almost the opposite end of the DP-X1 yet still incredible for music! Just remember, you will lose out on the other benefits that the DP-X1 offers outside of sound quality.
EDIT:
Added some extra bits, specificaly the DP-X1's sonic capabilities.
Jun 30, 2016 at 10:44 AM Post #9,794 of 16,328
  £25 customs for my Dignis case
.. I never liked having money anyways!
I can't wait to have it though, looks really well designed.
Yeah dude, it sucks, but personally, well worth it!
Jun 30, 2016 at 10:48 AM Post #9,795 of 16,328
  Just in case 2 slots and 200GB per slot isn't enough, Sandisk has just announced not one but 2 different 256GB microSD cards, competing with Samsung at a lower price!  Yay!
 See the announcement at: http://www.theverge.com/circuitbreaker/2016/6/29/12057654/256-gb-microsd-card-sandisk-western-digital-fastest
It's definitely not enough. :)
Bring on 512GB!
I'll be watching the prices of these very closely. Currently I have a 128 and a 200. Most likely I'll just get a single 256 (I don't have a dual card dap yet) and move the 128 to my phone or something.
I like that Sandisk is taking this approach, I don't need speed for my use, I need capacity, reliability and a lower price.
EXCELLENT! I've been waiting on the lower cost 256 GB MicroSDXC cards from SanDisk, and this is perfect!
Will see if I can afford one Extreme when it's out and another Extreme at a later date, or instead a Premium first then a second Premium later.
Really need 512 MicroSDXC cards to be honest...
