Hi
Hi TheOneInYellow
Doesn't seem to be software updates for it. I'm running version 0.1.3
I have a balanced cable coming from surf cables, should be here soon. I'm using tidal at the moment as my source for music, do find it a tad tinny through my shure Se 535? I also noticed there is no eq unless you are using the music app?? I do have a set of Dunu 2000 also give them ago.
Here is one picture anyway. [attach]1663394[/attach][/quote]
[quote="loungecat, post: 12682316, member: 451966"]
[attach]1663399[/attach]
[/quote]
[/spoiler]
Awesome pics dude, thank you for sharing!
Regarding EQ, that is locked to Android music apps you choose to use, including the Onkyo Music App (or the Pioneer Music App if you can find the API for it; that app is exclusively used on the DP-X1's baby brother, the Pioneer XDP-100R).
The DAP was designed to be used with the official Onkyo Music App and has digital filters (Short, Soft, and Sharp), so try that for a different sound signature for locally stored music (internal or MicroSD cards). These filters are exclsuive to the Onkyo Music App however.
Other apps might have differing results and features.
There are also three huge global, universal Android audio adjustment settings in the DP-X1, found in the Sound settings on the Android OS settings page:
[list] [*]Lock Range adjustment (actually change the timing accuracy of the clocks for the DAC's!),
[*]Max volume limiter,
[*]Gain stages (Low, Normal and High). [/list]
Furthermore, there is also a universal unbalanced, BTL balanced, and ACG balanced settings in the top-down quick settings menu too (also via widgets on the home screen).
Have fun!
