audionewbi
- Jan 24, 2010
Looks good. Are You able to tell what material is it?
if I find any more information I will share it, sadly best I can do is that link above.
ForumMod9 » Tue Jun 21, 2016 8:11 am
Hello tony1234, All issues regarding playback from a third party app are being looked into currently. Our head engineers in Japan are aware of the issue and working on a firmware update to address these issues. Thanks, FM9
sq3rjick » Wed Jun 22, 2016 11:18 am
Tony,
I've heard that if you set Tidal to use the internal storage it resolves a lot of the static issues. Besides that, try to not use High Gain and it should be less apparent.
Should be able to tide you over until the 3rd party app issue is resolved.
I think yes - will try tomorrow.
Pairing with Mojo - can't see any technical problem in pairing.
Ok, this was posted earlier in this thread (thank you to the original poster!) but yes there will be a software update regarding 3rd Party Apps having stuttering, noise or other issues (link here):
Supposedly there is a quick, short-term fix, please see the quote below:
As with any DAP, there are usually software and firmware updates, fixes, additions, etc. If you wish to have a DAP that works out-of-the-box, the Altman Terra-Player is one option of many.
Otherwise, for those who don't mind continuous improvement of their DAP's, especially the Onkyo DP-X1 and Pioneer XDP-100R, rest assured, you will be looked after.
Yes - but ... no progress from December 2015.
I must also re-iterate this, and I would like this to be taken seriously.
If you have issues with your DP-X1 (or any DAP), do post on this forum, but if the issue(s) is(are) something beyond the scope of fellow Head-Fi'ers, contact the manufacturer. seller, etc.
Did - answer - "sorry, we are working on those issues"... 6 months with no positive result? Ridiculous.
I say this not to be rude or mean, but the issues that a certain group of Head-Fi'ers raised earlier this year regarding noise and 3rd Party Apps was only recently, this month, been made aware to Onkyo; I strongly believe that those who cited the issue(s) had not contacted Onkyo at all, based on information that I have been able to glean and the contacts that I have spoken to.
As you can plainly see, Onkyo are willing to help and resolve issues, either on the software side, or to stop manufacturing production in order to improve QC and durability.
Sorry - I didn't see anything.
Yes, any audio maker can have issues and teething problems, such as Onkyo with the DP-X1, but the mark of quality and reassurance of such manufacturer's is how they try to resolve said issues.
Not try - they MUST resolve issues, not try. Till now - done anything. My old Sony z3 still receiving updates every 1-2 months. X1 - nothing from December 2015.
However, it works both ways; they too need our support and feedback, directly.
Please, please do contact them and post on this forum issues that maybe beyond user scope, because this will quicken resolutions and may even benefit both manufacturer, or fellow audio companions, and ourselves.
Did it again
Shame that Onkyo guys not reading this forum, as other companies do. (Another minus in their work with customers.)
Thank you, all of you.
Hi guys, very new To audio stuffs esp on balanced cables...
Would like to seek some help here, I wanna connect dp-x1 to my yaqin tube amp. Possible to connect it in a balanced mode? (Which uses both dac?)
Thanks in advance
No changes in software, No changes in hardware - the same complains stil going on and on. Soon my balanced going to die - one channel contact loosens. Onkyo lost their face to me totally.
Did you buy yours from Price Japan?
It seems like there are a few distributors out there where they are having issues with there product. I bought mine directly from Onkyo I had to pay 799.00 USD for it but (knock on wood) I have zero complaints, everything is great. I've had this about 2 months and use it almost daily.
Do your Yaqin have balanced input/output? I think, not possible without modding all amp.
Did it again
