- Jul 9, 2013
What's the point of rooting this device? Doesn't it void the warranty ?
Shouldn't void the warranty, no. A warranty covering hardware should be unaffected by software changes. Like I said, we're not flashing new bootloaders or custom ROMs; there is no change to the firmware. Just a small change to userland software. Onkyo doesn't have an efuse that gets blown when rooting (unlike, say, Samsung), so if you remove root or factory reset (losing root in the process) there should be no way to detect that it was ever rooted. But then again, I bought my unit grey-market from Japan while I am in the US, so I wasn't exactly worrying about warranty issues. Rooting gives you more control. A lot of people like more control. Most people will have no need for it. For the majority of people, it's best to ignore the whole root thing entirely. But for those who want to know if it's possible, yes, it is.
Unless you really know what you are doing, I would advise on holding off on rooting entirely. You can brick the device if you mess up (but from a software perspective rather than a hardware one). I will post an update when the next firmware comes out and let everybody know what steps are necessary to get the update if you have root (if it installs just fine, if it installs just fine but wipes root in the process, if you need to wipe root to install, or if you need to factory reset to install).
As long as you are careful and are okay with some risk, you should be fine. Personally, I wouldn't have any moral or ethical issue sending my unit in for a warranty repair if it were for a hardware fault (like the balanced jack coming loose), but I wouldn't send it in if I managed to brick the bootloader. Just be careful and know that rooting comes with its own risks and other rewards. It's all about balance and being able to accept that the risks are worth the rewards.
