This rather unceremoniously secured to the back of my Mojo with black tape and then covered over with the Onkyo stock case
(only 256GB SD card for now but looking at 512Gb once they come down in price)
Looking to get another one of these once prices of SD cards start to fall. Just image 1Tb of files in my pocket
I'm patiently waiting for the 512 GB MicroSDXC cards this year, and then the big price drop near Christmas
Btw, I get using single-ended DAC's or amps to beef up single-ended DAP's or phone's, but why would you bypass the overall majority of the audio chain in the Onkyo DP-X1?
Surely that's counterintuitive...
Now for me, if I wanted extra power I would buy the ALO Continental Dual Mono because it has balanced analogue in and out via 2.5 mm TRRS jacks. That means I could use a nice DHC cable, output my DP-X1 in balanced at 0dB (max volume) and that goes into the balanced in of ALO CDM.
This setup uses all of the internal circuitry (esp dual ESS DAC's), effectively bypasses the dual ESS amps as they are working as line-out in balanced mode, and I can have greater power.
However, I really don't understand why someone would use something like the Mojo with the DP-X1 and bypass it's actually selling point features.
Don't get me wrong, I'm not getting at you at all, I'm just fascinated by this stacking stuff.
Q for any owners:
Does usb audio output to other DAC work with third party apps like tidal?
Yes.
Onkyo DP-X1 is also full Android 5.1.1, so OTG will work as standard.
By doing this, you bypass the audio circuitry of DP-X1 just like any Android device.
Dignis clad DP-X1 and Chord Mojo
See above, first reply.
You can't go wrong with Dignis, I have it and its great, in addition they gave you a screen protector and 2 wraps (that protects the metal finishing of the exposed jack areas) and a cleaning cloth. It's an all in one set up that pretty much spells classy.
I'll get it, just not yet. My DPA-PUX1 will suffice, for now.
3.5 mm SE output via one DAC
2.5 mm balanced out using 2 DAC (one DAC for left and another one is for the right).
Of course, the SQ of balanced output is far more superior than SE one.
Small notes
- 3.5 mm TRS single-ended headphone jack = 1x ESS SABRE ES9018K2M DAC's and 1x ESS SABRE 9601K amp
- 2.5 mm TRRS balanced headphone jack = 2x ESS SABRE ES9018K2M DAC's and 2x ESS SABRE 9601K amps
By having two DAC's and amps, noise floor is massively reduced and you gain greater resolving power.
That's the theory behind Balanced audio chain, and some consider this to be superior than single-ended.
The truth is both single-ended and balanced are both amazing if implemented well.
Me? First time I used balanced gear was with Onkyo DP-X1, and I'm sold.
Thank you guys. And i know that this may be an elementary question but are most of you running a separate amp to this device? I like the fact that i can hookup a decent pair of hi-res headphones (portable like the EL-8, Oppo pm3's etc) and go. I personally find it cumbersome to add and amp etc. thoughts?
I'm not, and if I did I would ONLY get an amp, most killer s balanced one like ALO Audio Continental Dual Mono or Cavalli Audio Carbon, get a great DHC balanced cable, and set my DP-X1 to max volume.
But I don't and use DP-X1 as is.
Edit:
Sorry guy's about this awkward post, I'm typing on my phone and had a work call...
