masterpfa
- Dec 30, 2014
I totally get your point. I apologise if all I am doing is repeating hearsay. My suggestion is that I have read enough in here, of problems, that it seems that if streaming is my primary reason for buying the DP-X1
then I may be disappointed.
As answered below IMO the problems may in fact be the Tidal app and not the implementation on the DX-P1
Tidal works with the DP-X1, Onkyo even has it as a recommendation on their Useful Apps app. Also I believe they have a partnership(Onkyo and Tidal) to play MQA streaming some time in the future so this alone is a good sign that Onkyo plans to improve compatibility with Tidal.
One of its problems right now in my experience is that it has some random stutters which I think only happens when the screen is turned off. Then there is the issue that I cannot out tidal with my Chord Mojo seems like USB interface is not supported with Tidal, outing to the Mojo works only by using the stock music player, and UAPP in my experience
I get the odd random stutter with my desktop Tidal over WiFi so isn't the odd stutter just the nature of streaming, or do you mean you get even more stutters with the Onkyo than you do normally with say a computer?
I have occasional stutter with Tidal no matter what I use, PC, Mobile Phone or DX-P1 and I have come to accept that as gremlins that need ironing out with Tidal and not solely experienced in my case just on the Onkyo.
But with MQA on the Horizon this may also give a clue as to how Tidal and Onkyo have worked on the DAC and it's use in this device so I wonder if that would mean Tidal using the
Dacs: 2x ESS Sabre ES9018K2M and Amp: 2x ESS Sabre 9601K
and not the Snapdragon's SoC DAC?
