ReizeiMako
- Jan 13, 2015
Music software updated. Folder browsing is there.
Wow, it comes early than expected. Thank for the news!
Still listening and testing out my DP-X1 and will share impressions soon. However, I experienced a few "quirks" that may help some folks if they saw the same:
- I recommend you erase/format your SD card inside the DP-X1. I did a FAT32 format and copied 350 GB of music across 2 x 200 GB sd cards and when I plugged them into the DP-X1, it just wiped out all files. I had to format with the DP-X1 and after that I could use my Mac's SD card slot or AFT to copy files to the sd cards without issue. Mac users, you should use Blue Harvest to remove all of those extra Mac OS hidden files.
My unit is coming tomorrow but this statement scares me a little. All my micro SD is formatted as Fat32 for compatibility with my Plenue D. Is this right that if you insert Fat32 cards into the Onkyo it will wipe out the card? A search seems to indicate no one else reporting such a issue.
Make sure you have wi-fi up and running.
Go to Play Store on main screen.
Search for onkyo music player.
Scroll down to Music (app - Onkyo Corporation), will have installed in green next to it.
Click on it and update.
Easy.
Are you running those Pros SE or balanced? I can only run SE and I concur, they are a nice pair. Background is pitch black, too.
I do prefer the sound of the HA200 to the iPhone but don't really want to carry it around so I am very tempted to try the DPX-1.![]()
Cool finally folder browsing!
