ExpiredLabel
- Nov 1, 2012
Thanks for the link to the article, currently having a chuckle at the comments section.
I completely get where your coming from, however in this case I would simply chalk it up to being like the age old discussion on burn in. Those that are on the side of the fence that feel burn in is real, opposite those that feel its very much not real. Either way keeping an open mind and in our cases open ears can allow us to further enjoy the music we already enjoy. Don't let people who are CLEARLY not open to outside suggestions ruin something for you I can only presume hold close.
So, roughly how much time do you have on the onkyo so far? Any difference in sound since originally using?
What I have always found interesting on the subject of burn-in, is this. At what stage does the opposite (burn-out) happen, when you notice your equipment's music quality deteriorating, and hence you need to throw the offending equipment away even though, if you are honest, it still sounds reasonably okay?
^ I've asked technical questions about how this can happen, but nobody has been able to actually explain this process. So we know that an OS would have global handles that a programmer would know exposes things like video or audio paths that ultimately would have to know what hardware is installed and how it is configured. At least that is an educated guess. So Onkyo would need to program I assume methods that would look for the audio output from these apps and route them to take advantage of the hardware DAC, otherwise I assume that Android has standard audio handlers that the app would communicate with that are then processed in the appropriate SoC on the CPU. If this simplified explanation is essentially accurate you would think that it could be done, but it is hard for us to know if this is actually a big undertaking or not. While it sounds like nothing to us, same as folder browsing, perhaps it is actually a lot of work to code this functionality?
