fumoffuXx
- Apr 9, 2014
Hey guys,
ANy idea what are the changes for the latest firmware?![Eek! :xf_eek: :xf_eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Sandisk makes 200gb microsd cards so 2x 200gb +32gb = 432gb
Anybody who hears a difference between DAC digital filter settings (slow, fast etc. roll-off), also hears the difference between 44.1kHz and higher sampling rates, because at higher rates DF works at higher frequencies and, as such, its mode does not matter.Don't waste your money. There is no audible difference between a normal 44.1/16 FLAC file and higher bitrates.
Hey guys,
ANy idea what are the changes for the latest firmware?![]()
Hey no problem. I edited my post. Had a few too many last night while counting down the days to go. In hindsight maybe I was a little too candid. And yeah, I know how to piss people off - apparently. To tell the truth i am a little worried about how long I may keep - this is real midnight express stuff (never seen that movie? rip and encode it down to watch on the DP 1x)
You may not hear any other difference, but it's wrong that there is no one at all.
thanks dude couldnt find it lol
Yes I am one of them
The ZX2 is great, especially as @Whitigir always says the amazing tonal body and the nuances that the ZX2 is able to convey.
I wanted more output power, and balanced of course, and also a DAP's choice is about synergy. Ah and The walkman connector made the ZX2 a clumsy choice for Mojo transport on the go.
I think ZX2 pairs beautifully with neutral or analytical IEMs / headphones as it adds a touch of warmth and builds on technical ability / potential to add nuances and life to them. On the other hand I think DP-X1 is pairing beautifully with warmer IEMs and headphones, bringing it's technical abilities with separation, transparency, detail, soundstage and speed. That's of course oversimplifying it and my own take on mixing source / phones. For example the warm NightHawk open up with the DP-X1 and come to life showing technical abilities that you would just miss otherwise.
Would you say Noble K10s fit the ZX2 or DP-X1? And how would a cable upgrade to Double Helix Symbiote fit in with both those players?
I have never heard the K10 what kind of signature has it ? Never tested Double Helix Symbiote, I wouldn't know and of course that's my own take on source matching, your mileage may vary.
is it possible to save the current firmware on your device before you upgrade to the lastest, ie. is it stored in a folder you can access?
Technically yes, but you would need to root the X1 and install a 3rd party boot manger like TWRP. Unfortunately I doubt the general Android developer community will bother to root the X1. If any Headfi member is a Android developer, maybe we can do a GoFundme and get root access.
-OR-
Do we have a brave soul to try this - https://www.oneclickroot.com
