bflat
Hey guys. Can anyone recommend any apps to clean the "junk" files from my ALACs before loading them into the DP-X1? I'm a Mac and PC owner so I really don't wanna change the original files...just wanna try to save some space on my SD cards. I think I read about one earlier in this link but I couldn't locate it again. Thanks.
Assuming by "junk files" you mean the spotlight and trash hidden files Mac OS puts on your SD card, use BlueHarvest from the app store to clean those up.
Alternatively, for Mac, format your SD card while installed in your X1, then use Android File Transfer utility to copy your files. Mac OS will not write hidden files when using AFT.
