Hi all, just curious as to whether anyone has tried either the Noble Savant IEM's or any of the JH-Audio/A&K Siren series with the DP-X1 (in either SE or Balanced, but preferably the latter or both)?
With regards to the Noble Savant, a website says it: "utilises a Westone 2 pin socket connection and is a 4 cable braided construct with individual plastic wrapping with a rather basic plastic
‘Y-split’ tube and a second short tube for chin locking". With this in mind, what would I need to do to make it compatible with the DP-X1 in balanced mode?
And ideally, could I also get a separate set of detachable cables which are SE, so that I can use Balanced for the Onkyo but (for example) SE on a Chord Mojo?
Of the JH-Audio siren series that I've demoed, I liked the Roxanne's best (more than the Angie, albeit on a quick listen).
I can't afford either at this time, but they've recently released the new Rosie model at around £799 (UK).
Apparently, it comes with Balanced cables (A&K compatible, hence compatible also with DP-X1 I assume) as well as a set of SE cables too.
The basic model of Noble Savant is around half the price of the Rosie. Having tried neither, I can't comment on sound quality/signature between the two. Can anyone?
But if the Noble could also have balanced and SE cables, then it's also a question of sound quality vs the Rosie, and synergy between both IEM's and the DP-X1 and Mojo.
Thanks for your thoughts, and apologies in advance for any mistakes or misapprehensions I may have made!
