muso
- Nov 25, 2015
The way I understood it from the interview done at the press launch was that there are two balanced modes both using the 2.5 plug. One uses both dacs and amps in parallel. Ie one per channel. The other is ACG which uses them in serial. Ie the first one converts the signal and the second one smoothes it removing jitter etc. You change this internally I believe. Anyone that has one please shout if this is wrong!
FYI customcans will make a copper/silver balanced cable for sennheiser which ends in a 2.5mm. You can choose the colours and it costs around £60.
