che15
- Oct 31, 2009
Can some please post a link for this upgrade website
I asked about the cost of he Battery Upgrade, and it's HKD$500 (USD$64).
He said he can also do some other internal parts upgrades, as well as adding some shielding.
How much of an upgrade to the battery is it? I think the OEM is 1800mAh.
Shielding will need Ground to even work...those are simply pasted on copper tapes...and not functioning the way of shielding. To correctly shield the Wm1z, tape those copper foil on the plastic black cover casing and have it connected to the 1z main chassis body. Take out the NFC and Bluetooth antenna, and now you will have a 1Z without any receptions for any wireless signals, then together with a properly shielded Wm1z.
**ultimately** you can try and CAD a file for the back plate (replace the leather one) milled out from pure copper and have it gold plate treated by a custom shop, screw it on with the screws holes already made in place by Sony engineers, and voila** now, that is a properly shielded 1Z....not those foils
*also* taping those copper foils inside the 1z is a pretty bad idea. You will only need 1 little piece which fell off during the procedures, unnoticed, and it could short out all short of thing and create some pretty magic smokes.
Just some honest opinions, ofcourse you can do whatever you want to your player, and what you think is right.
I am very surprised in a bad way to see how many people claiming on their modifications .....do they even know the basics behind it ?
But the same method been applied to desktop amplifiers for many years. I think many ears have proven it.
I don’t doubt a proper shielding has “improvements” to observe. I do know the fact that shielding will not work without a “proper ground”. What in the heck is the basics of shielding ? But again, as I said, people do with their device and money what they will
