I have been running my Granbeat for a week now, and the idea was to summarise my impressions. I do not have any PC DAC setups anymore (used to own iFi Nano and Mojo) and would refer to the full audio system instead (Opera Quinta+Bryston amplification-prosessor+Teac Isoteric) for serious and proper listening. The Onkyo DP-CMX1 is for the mobile and on-the-go application (+ FW01, ER4, RP-HD10) and travel.
In a nutshell, it appears I am a little buffled, in a good way though. There is nothing to write back home about. The Granbeat simply does what it says on the tin. And does outstandingly, with noble authority.
The sound is big and bold, very meaty at times. It is quite dependable on the track’s recording quality and can be punishing. This is what I expect from the product at this level. I enjoy every type of music with it, especially female vocals. Streaming Radio Swiss Jazz (my favourite) at 128 kbps is a real pleasure. DSD files are magical. Ordinary FLACs sound delicious. I would probably even say that it matches Mojo in this sense, at the same time being not so mellow on the clarity and precision side. IMO, the Granbeat amounts to the analogue studio sound with the right material. I also noticed that after a week’s use its SQ improved – it opened up a little. Hopefully, it will continue that way! I have not used the balanced output as yet, the cable is on order. Also still waiting for a flip case to be released.
The mobile phone section is not thrilling, but it has everything you need for communication. One has to bear in mind that it is a high-end DAP with a phone as a useful addition rather than the other way around. I totally approve this principal of a reputable hi-fi company going into the mobile market for the music enthusiasts. The camera is also basic – you just have everything you need in this section. And I personally like the weight and kind of a military grade metal enclosure, not uncommon for the best hi-fi equipment. The Granbeat is not cheap but is worth the investment if you can afford it. I wish I had more time to spend with it now.
