hciman77
- Feb 25, 2004
Ah some reasoned debate, excellent. True these approximations are based on certain assumptions but they are not mine as such so I strictly cannot vouch for them, I did separate them from my preamble sorry if I did not make that clear enough.
It is true that LP does have Freq response extension beyond 20K that CD (not at all arbitrarily) cuts off but getting anything like a linear response at these higher freqs on LP is difficult at other than very low level and the DR is severely limited above 20K, similarly LP is "summed to mono" below 80hz.
No, I would guess that a smaller stylus would cause less distortion in the vinyl which limits the retrieval evan if less surface area was caught so some algorthm must be required to work out the optimum size - I do not know how one would do this, my figures are courtesy of Arny Kreuger.
Jitter is really not a problem on anything but the rankest modern kit and is in essence similar to turntable wow and flutter (speed variations) which on even a good TT runs into the 0.02% range which audibly degrades solo piano, by comparison jitter even in the 1000s of ps range is much less intrusive, in fact nobody has shown CD jitter to be empirically audible below 10ns.
As for preference, dunno, I grew up with Vinyl and even bought (still have) a pretty decent turntable in 1984 but the noise drive me up the wall, I listen to a lot of classical and the various noises (including wear and clicks and so on) on the quiet passsges were dreadful, by contrast my 1984 Mahler's First CD (Solti/CSo) sounds as good today as it did in 1984.
Preference is an odd thing, many Americans for instance like peanut butter in chocolate, this is something I just cannot get my head around, but back in the 1980s my favourite dish was pork pie and yoghurt so I cannot talk.
Peace and Love
Originally Posted by memepool /img/forum/go_quote.gif interesting analogy but logically flawed, even if your mathematics is correct which it may well be, you are assuming vinyl can be measured in a way which analogises roughly with the way CD is measured which is a nonsense because the way "data" is retrived from the two media, not to mention the "data" itself is completely different. By your reasoning for instance a larger stylus surface area would = more information being retrieved which is facile and demonstrably untrue if you've ever listened to a turntable. When CD was released it was measured by the metrics applied to turntables and open reel such as noise floor and speed stability, areas in which it quite obviously betters turntables and open reel cassette. It is inferior in frequency range but of course in an analogue system frequency range is defined in tandem with noise floor whereas a CD arguably has a superior frequency range within the commonly percieved audible spectrum coupled with a much lower possible noise floor, provided the signal is kept to average levels. But then other problems were identified with digital recording which are completely alien to analogue recording such as jitter. All in all there are various theories as to why analogue sounds better to many people but these point more to gaps in our knowledge about how we percieve sound per se and "process" it in our conscious minds (assuming we have such things). |
Peace and Love
