Official Sony WF-1000XM3 Thread - Noise Cancelling True Wireless Earphones
- Thread starter monini13
I have a problem with them, left earbud has rock solid connection but right earbud disconnects randomly and after a few seconds reconnects again.
If i select google assistant to right earbud it gets worse constantly disconnecting both earbuds.
assassin10000
- Sep 20, 2009
Sadly, nothing's changed. Both earpieces' behaviour stayed the same. Moreso, it seems to have carried over to my DAP as well (I originally had them paired with S8+ only). So it seems the problem is with the earpieces, since my phone and DAP have nothing in common. What's strange is that it just suddenly decided to stop working, one day when I decided use the right one for a Skype call so it won't be so visible during the call.
Unfortunately issue persist after factory reset, right earbud sounds cuts off and after a few seconds starts blinking blue and reconnects.
aceedburn
send it back for a replacement.Unfortunately issue persist after factory reset, right earbud sounds cuts off and after a few seconds starts blinking blue and reconnects.
jasonb
- Sep 14, 2010
fyleow
- Mar 15, 2002
I just got a pair today and they sound pretty good. Are the wax guards on these replaceable? I’ve owned a number of iems and they’ve all need to be replaced at some point. I searched and didn’t find anything except comply tips with built in guards
jasonb
- Sep 14, 2010
I've had my wf1000xm3 for almost 2 weeks and have been using them everyday. I'm really enjoying them. I like the noise cancelling, the ambient sound, and the EQ. I actually was more interested in the ambient sound mode than the noise cancelling. There are definitely times I want to enjoy Bluetooth earbuds but still be able to hear around me a bit. They fit me well with Spinfit 360's, Comply foam, or Dekoni Bulletz foam tips. I should have gotten these sooner, but they are a much better deal at $180, than at $230.
I like these earbuds with ANC off. However, ANC keeps turning on every time I put these in my ears. Is there any way to remember ANC setting?
I'm using the Android app.
jasonb
- Sep 14, 2010
Nope. Default is ANC on.
nc8000
No
Ok, thanks for the quick replies! Its a shame though, auto connect serves no purpose if I always have to configure my app anyways..
jasonb
- Sep 14, 2010
I've been trying these with the Wavelet Android app and the autoEQ and I'm liking the results. Has anyone else tried this? Using with Spotify premium.
bizkid
- Jan 18, 2006
Just got these yesterday and had a 4-5 hour session instead of sleeping I'm not an IEM fanatic (yet) but I really like the Sonys. They sound better than the KZ ZS7 I had some time ago. Also comfort is better. I always had to readjust the ZS7 and after 30 mins they would move out a bit and break seal. No problems like that with the Sonys. I'm also surprised by the tuning, it's relatively balanced and only slightly boosted in mid bass with slightly recessed mids. I expected much worse Now I kinda want to invest in some good cabled IEMs. This Hobby.....
