DSD remastering engine is simply put....an algorithms that utilize a processor IC and a programmed algorithm to process sigma-delta modulations instead of using DAC-IC. When you turned on DSD remastering engine, you are using Sony own algorithms and DSP processing chip. The AKM is there to conduct a pathway (multi channel 1 bit) into the low-high pass filtering to have analog out
Another way to put it is that you are using Sony Software and DSP professor chip to Convert digital to analog signals...instead of the AKM
The reason why TA uses FPGA is because S-Master can not by pass 1 bit DSD informations. Unless it is processed directly by itself and into 2 separated channels, hence Balanced out only. So Sony had to use FPGA for this purposes.
DMP also uses AKM for this purposes
thanks a lot for this explanation. Now I understand.
and so.... How does this affect Tidal/Qobuz streaming (streaming done by a phone connected via cable or LDAC to the DMP-Z1) ? is then Streaming as good as local redbook playback ?
BTW; could you tell us which headphone you use with the DMP-Z1 or which headphone you believe offer the best synergy with the DMP-Z1 ?
