I know what you are saying, however I've been active here long enough to know who to trust and who not to trust. I know which reviewer have taste similar to mine.
That is why whitigir words carry value for me.
Because DMP-Z1 has the same Sony proprietary IC chip (FPGA) as Walkman WM1A/Z and on top of the additional AK4499EQ Dual. This is why I was able To tune the Walkman WM1A/Z in references of DMP-Z1. I also have achieved the Golden Milestones of DMP-Z1, and that is DMP-Z1 Galaxy Firmware.
Sony FPGA chip can act as either a DSP interface, also a programmable sigma delta and or both. It is a multibit professor , and in order for 1 bit pure DSD to pass through, it needs an additional Chip that can handle 1 bit info, and on TA-ZH1ES, the choices was to choose an additional FPGA to be programmed as 1bit. On DMP-Z1, the choices was to go with AK4499EQ.
While The Walkman also has this same FPGA but can not use “DSD Remasterting” feature because the S-Master can not handle 1 bit. It is Direct Multibit only and that is why only Native DSD is able to play over balanced. On the TA-ZH1ES, the additional FPGA is handling this 1bit stream and directly feed S-Master with it. Then on the DMP Z1, and as a different line up of devices, it uses Class A/B IC TPA as amplifications and no S-Master was used.
There are many reasons but the DMP Z1 was built this way because it satisfies many goals: compact and transportable form, powerful output, DSD Native handling....etc
The DMP Z1 has the Privilege to utilize the Different Sigma Delta Techniques on the same modulators Velvet Engine by AKM, the AK4497EQ and 6 additional Digital filters
Why AK4497EQ ? Because it can do 128Db Dynamic range. Anything higher than 120Db dynamic range is already beyond Human hearings. The question here would be “Could Sony squeeze everything out of it?”
By the way, Song only call this Proprietary IC chip as Sony Proprietary DSP IC. I see it being similar to an FPGA that can be programmed to handle many tasks, so I always related to it as an FPGA.
