audiobomber
I sent the dark-sounding Amiron back and bought the DT 1990. No regrets, I love the 1990 (but only with Analytical pads).
Not possible to hear before buying.I urge you not to buy the V3 without an audition. It is very different than you would expect. Extremely dark sounding. Nothing like the traditional Beyer sound. It is also 25 ohm instead of their classic 600 ohm T1 v1 and v2. I think this was an attempt to get more into the plug into portable devices like your phone. You must hear before buying.
A pads? Is that the velour pads?I sent the dark-sounding Amiron back and bought the DT 1990. No regrets, I love the 1990 (but only with Analytical pads).
DT 1990 is a safe choice if that fits your budgetNot possible to hear before buying.
I must take a chance.
I also can get DT 1990 for a good price.(dealer return) 35% off
Beyerdynamic dark? Im not used to dark sound
Have tryed amiron. They are boring.
But I like my 1770.
Both sets of pads included with the DT 1990 are velour, but they sound different. This review comes closest to my opinion of the DT 1990 Pro and has photos of the pads, with a good description of their sound quality. The only thing I would add is that the B pads are more likely to add sibilance, IME.A pads? Is that the velour pads?
Using Velour on my 1770. Most comfy
Fits my budget better than T1 G3DT 1990 is a safe choice if that fits your budget
