Give me email.I have it 8.1.Hi, can anybody share the firmware and drivers for F.audio FA4? I can download.
Thanks.
Obscure Chinese DAPs
- Thread starter pekingduck
fitzyssbuna
hi i am looking for firmware for ruizu A55 and can't find any at their website ! any help would be appreciated.
Juan Antonio
Hi, thanks you, but has been canceled purchase of FA4 and i will check Z5.
Thanks again.
Laidenwind
Greetings! I'm new here. I bought a RUIZU A55, and it came with this same bug. Others mentioned that this bug was fixed in a firmware update but my device says that is up to date and stil has the same problem. Does anyone has a firmware update I could manually install for this or any other recommendation to fix this little issue? Thanks!Hi again! I just got my RUIZU A55, it works awesome, and the sound is nice, but there's a problem with the latest firmware. When I turn on my dap and select track there's this LOUD clicking sound and it plays track on max volume, the volume knob is not responding. This is fixed by selecting the next track. Nothing special but still annoying. Didn't you encounter the same issue? Btw, any finds on the case?
RedHarlow
- Dec 29, 2013
Connect the device with your WiFi.hi i am looking for firmware for ruizu A55 and can't find any at their website ! any help would be appreciated.
It automatically shows you new firmware updates.
XTF1
- Nov 9, 2014
Related to the Zisan (new spelling of Zishan!) Z5: GAD, the Zisan-related “higher-end” brand has released a portable, battery-operated, tube/class-A amp. $99 on AliEpress—several stores, search for “ADV amp”:
It looks like the successor of the AD-III and it is interesting.
- 3 switchable modes: 3.5 to 3.5 SE, 900mW / 32Ohms; parallel, high power (assume high current), 3.5 to 3.5 SE, 1350mW / 32Ohms; and 4.4 to 4.4 balanced mode, 1620mW / 32Ohms.
- No feedback class-A, triode vacuum tubes with 30V internal power supply, direct coupling output (no capacitor rolling off the bass).
- +/-12V internal power supply.
- 4x elements (18650?) 9600mAh battery.
- USB-C 5V charging.
- USB-C 5V power-bank function.
Does anyone have the Aigo Eros Ten and, if so, are there any English-language instructions for it? Everything seems to be in Chinese
Actually, all ok, I found the English-language option in the settings!Does anyone have the Aigo Eros Ten and, if so, are there any English-language instructions for it? Everything seems to be in Chinese
Juan Antonio
Hi all, can anybody know a site to download firmwares, manual etc... for Zishan Z5?
Thanks.
Thanks.
InvisibleInk
Nothing here, http://zishan.ru/files/, yet.Hi all, can anybody know a site to download firmwares, manual etc... for Zishan Z5?
Thanks.
Juan Antonio
XTF1
- Nov 9, 2014
Just checked on Baidu, only 2 files: the txt file with FW upgrade instructions, and the pdf user manual (both in Chinese). No FW file (Z5 app.bin) yet.Nothing here, http://zishan.ru/files/, yet.
Juan Antonio
Hi, thanks.Just checked on Baidu, only 2 files: the txt file with FW upgrade instructions, and the pdf user manual (both in Chinese). No FW file (Z5 app.bin) yet.
Does anyone have experience with this model, which seems quite promising, not only because of the cable that comes with the headphones, which is worth much more in my opinion, considering the price? It is also said that it is a limited edition of 50 pieces. And I admit that I am very interested to I buy them, but I didn't find any tests anywhere except those 3 ratings on Ali
https://www.aliexpress.com/item/100...4396e3131!12000032530030552!rec!SRB!172357965
Thx in advance.
Thx in advance.
I bought them because the number of remaining pieces is decreasing hour by hour. At the time of purchase, there were 11 left, and now after me 10. I will share my experience with you when they arrive and when I try and test them.
Total: 76 (members: 0, guests: 76)
